What the hell is Going On...
Old Oct 9, 2001 | 01:36 PM
azn g ryde's Avatar
Thumbs down What the hell is Going On...
Man I pulled into my garage today and turn my stereo down. Guess what i heard. I heard a clickin sound in my engine. I shift into park adn the sound goes away and then I shift to reverse there is the sounds, nutural, all the gear and even s/s mode. there was the clicking sound. Thats not normal huh... should I take it back to the dealer. My Tl is almost 3 months. What to do. does your TL do that
BG
Old Oct 9, 2001 | 03:38 PM
rockinTLS's Avatar
Sorry, don't have any good idea of what may be the problem.
I think a trip to the dealer is in order.
Good luck.
Old Oct 9, 2001 | 10:15 PM
My sunroof squeaks and the subwoofer grille rattles, but nothing else. Sorry I can't help more.
Old Oct 9, 2001 | 10:53 PM
bh
turn off your AC and see if it stops
Old Oct 10, 2001 | 07:38 AM
Road Rage's Avatar
Not a Blowhole
Is the clicking engine speed sensitive? Could just be injector noise being reflected by your garage walls. Did this just start?
Old Oct 10, 2001 | 03:21 PM
Tag66's Avatar
subwoofer rattle
I also have a rattle coming from the subwoofer area. Were you able to fix it? I spent some time back there and inside the trunk and couldnt isolate the rattle.
Old Oct 10, 2001 | 03:49 PM
trippin555's Avatar
Re: subwoofer rattle
Try having a friend sit in the back seat and push up on the rear glass when you hear the sound. The dealer recently remounted my rear window and it fixed most of the rattles in the back. They also replaced the sunshade and that fixed the crackling sound I heard from the back.
There is still one slight rattle that I noticed when driving my car on the freeway, but my car has a lot of junk in it at the moment so I just need to clean it out before I try to pinpoint this one. I also don't drive my car as often as I used to so it doesn't bother me as much.
-Keith
Old Oct 10, 2001 | 04:51 PM
edgalang's Avatar
Purchased: April 28, 2001
Re: What the hell is Going On...
BG
I too have that clicking sound. If you open up your hood you'll notice it is comming from the driver side near the firewall. I believe thats the coolant pump since it would occationally turn off and on depending how hot it is outside. I never really noticed it untill after I put in my CAI which involves replacing a small section of the cooling line.
Old Oct 10, 2001 | 07:35 PM
rockinTLS's Avatar
Re: Re: What the hell is Going On...
Actually, there is a clicking sound that comes from a small vacuum(?) valve located on the firewall (drivers side). I asked the dealer about the noise and they pointed it out to me. I was told it has something to do with emissions and the sound is perfectly normal. I thought at first it was a noisy injector.
You can't hear it from inside, though.
Old Oct 10, 2001 | 08:52 PM
StypeCL's Avatar
My CL-S did that when it was newer, its the torque converter. My car does not click anymore.
datadr
Mar 23, 2016 01:39 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
DerrickW
Nov 15, 2015 05:52 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
