Weird Steering Wheel Audio Controls Problem
Old Jul 3, 2010 | 01:39 AM
finalcross's Avatar
When I got my TL the audio controls worked perfectly. Then after about 3 weeks I felt like I had to press the "AUDIO" harder for it to work. Then today I noticed that my Volume and Audio buttons on my steering wheel completely don't work. So I thought maybe a fuse? Then I tried my Cruise control buttons and they worked perfectly. So I thought maybe audio has own fuse? BUT THIS IS THE WEIRD PART. When I turn my steering wheel in either direction about 180 degrees, the volume and audio button works perfectly. I don't even have to press them down hard. But once I turn the steering wheel back to straighten the car out, the buttons don't work again. I have to turn the steering wheel left about 270 degrees or right 180 degrees from straight for the audio controls on my steering wheel to work. And my radio works perfectly if I reach all the way up there to change the station or volume. YES, I am that lazy.
Old Jul 4, 2010 | 01:09 AM
LSDave's Avatar
9th Gear
Sounds like something is messed up in the steering column. There is no fuse for the steering wheel controls. Its a direct wire to the radio.
Old Jul 4, 2010 | 01:50 PM
ThreePointTwoTeeEl's Avatar
3.2TL
There is a fix for this I believe. If you search you might find it or wait till someone chimes in.
Old Jul 4, 2010 | 03:03 PM
Triple_A's Avatar
Page 4 - Procedure B.
http://techinfo.honda.com/Rjanisis/pubs/SB/B03-015.PDF
Old Jul 4, 2010 | 07:06 PM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
Interesting - My '03 ASpec does the same thing. The top button can change the channel if pressed lightly. I found if I push it in all the way, release it all the way and repeat, I can avoid this problem. there are two phillips screws on the side of the control cluster "pod" - I may take them off and look at the contacts. I feel the "problem" is to do with the the angle / how the button is pushed ex: pushing it from the top or wiggling it.
Old Jul 4, 2010 | 07:10 PM
^NVM what i wrote - hopefully someone might find it useful
Old Jul 5, 2010 | 02:34 AM
finalcross's Avatar
Of course I tried searching and couldn't find anything.
And that link brings me to a blank page.
Also sometimes when I am driving at high speeds the audio controls work fine. And I noticed that when I press the down volume button, the volume goes up and then down which made me think that nothing was pressed but my up just didn't work. I have no idea how to explain this because sometimes it works sometimes it doesn't, if I drive this fast it works, if i turn this much it works, on a cold start it works, and much more.
Is there a easy way to open it up and take a look at it? Thanks.
Old Jul 5, 2010 | 12:17 PM
Update your Adobe Reader. I found if i let the PDF load it eventually worked.
Old Jul 5, 2010 | 09:57 PM
fsttyms1's Avatar
link works for me and opens right away. Been linking to that one for years
Old Jul 6, 2010 | 12:31 AM
finalcross's Avatar
Oh it works now. It didn't work for some reason yesterday. Thanks. This looks like a crazy job. I'm a beginner but thanks for finding the fix. Guess its an Acura problem.
Old Jul 6, 2010 | 03:24 PM
I have to add... On mine, if you push the button like you mean it, without hesitation, it works... (cars got its own taste in music)... It also helps to push the top half of the button...
Old Sep 10, 2010 | 09:58 AM
tspires's Avatar
I am have same problem with steering wheel audio control. Also cannot access .pdf link with solution. Help!
Thanks,
tony
Old Sep 10, 2010 | 10:29 AM
dukie564's Avatar
I Like Pie
i also have the problem with the volume up button changing the channel. Is there a fix?
Old Sep 10, 2010 | 10:30 AM
Ron A's Avatar
Administrator
Thanks,
tony
Welcome to the forums.
Link fixed.
Old Sep 24, 2010 | 09:31 PM
Feeelax's Avatar
03 TL-S 06 MDX
hmm weird. I got the same problem on my tl. But after pressing it for around 20 continuous times it starts to work normally... I ignore it.
Old Jan 24, 2011 | 06:41 PM
Metalhead's Avatar
I have the newest version of Adobe reader and I cannot open the link. I get this message:
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
Help please? I already have my steering column ripped apart, I just need to know what to do (bought a replacement audio switch and searched on here for how to get the back of the steering wheel off, only to find this post).
Old Jan 25, 2011 | 07:17 PM
03Atls's Avatar
Are those buttons supposed to light up on the wheel? I thought mine used to but don't anymore - or maybe I am imagining things
Old Jan 25, 2011 | 08:51 PM
Karanx7's Avatar
Unregistered Member
No they never did. Unfortunately =[
Old Jan 26, 2011 | 08:23 PM
03Atls's Avatar
Yeah would of been nice.
Old Jan 27, 2011 | 12:54 AM
finalcross's Avatar
They light up on my G.
Old Jan 27, 2011 | 02:17 PM
d4atls's Avatar
yeah this is actually a pretty common problem guys..... i got a notification from the dealer about having it fixed.... think it involves pulling the steering wheel and tapping small indentions in the contact rings that connect the buttons on the steering wheel to the rest of the harness in the column.... it's there so you don't have wires binding up when you turn the wheel.... too much trouble to be worth it for me... mine only does this occasionally....
Old Jan 28, 2011 | 10:18 AM
timberland73's Avatar
99 TLS6 08 TL
My volume up button changes the radio station on my 03 CLS6. But it only seems to do that when it's cold. After the car warms up, it's fine. I'm not even gonna bother with trying to fix it cause I'm replacing the factory stereo anyway.
Old Feb 7, 2012 | 03:25 AM
therealvtecfetish's Avatar
same problem here...volume up changes the channel and vice versa, it drives me nuts.
Old Jul 19, 2013 | 12:26 PM
MehrdadTL's Avatar
I have the same problem with my 03 TL. Audio and volume buttons doesn't work in most cases. Volume button sometimes changes volume and sometimes changes the radio station! also, down key sometimes increases volume!
My cruise button on wheel sometimes doesn't work (main green light is on).
Anybody can help pleasssse?? I couldn't download that PDF because of the same error with others.
Old Jul 19, 2013 | 09:05 PM
wrayman's Avatar
I pulled the control off the wheel and opened it. Blasted it with a good contact cleaner. It's a bit picky to work with but was much improved when I finally got it reinstalled. It has worked much better since then, but still some random failures here and there.
One of life's irritants.......
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
Charlespsu
Sep 2, 2015 09:54 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
