weak brake problem
Old Jun 10, 2003 | 10:19 PM
Exclamation weak brake problem
Recently my brakes have been giving me some trouble, they seem to have gotten really weak. While i'm driving it seems that it requires me to press the brake almost all the way down to get the car to come to a stop overall the brakes feel really weak. I took it to the dealer and they changed my brake pads, but after a weeks worth of driving they still feel the same.
A bit of history:my brakes were fine until i hit something on the road and cause me to blow a rear tire, obviously i know this caused the problem but i dont know whats wrong and the dealer said the change of brake pads is all it needed. Any suggestions what i should do next?
Old Jun 10, 2003 | 10:49 PM
Change the brake fluid. Sometimes after time the hydraulic charateristic may break down. Now as you press the brake pedal the fluid may compress more before actually applying hydraulic pressure to the piston in yuor caliper. Over time your brake fluid also collects moisture through condensation and it too will build up in your lines causing poor hydraulic pressure. Also by changing the fluid you will rule out the possibility that there may be any air in the system. my .02
Old Jun 11, 2003 | 12:10 AM
limitedTLS's Avatar
might as well flushed the entire brake system out with new fluided
Old Jun 11, 2003 | 01:40 AM
hellas's Avatar
Re: weak brake problem
you should have said that to the dealer. i'd look at brake lines
Old Jun 11, 2003 | 09:27 AM
bigman's Avatar
'Big Daddy Diggler'
have the fluid flushed out, get the stainless brake lines and see what happens.
Old Jun 11, 2003 | 11:05 AM
Strannik's Avatar
Re: Re: weak brake problem
Definetely. If it was fine before that, you may have damaged the brake line or the valve that deals with brake force distribution. Maybe your rear brakes do not work at all now. Have dealer check it out.
Old Jun 11, 2003 | 10:55 PM
Thanks for the help guys!
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
rklatzkin
Sep 23, 2015 04:08 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
