weak brake problem
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Recently my brakes have been giving me some trouble, they seem to have gotten really weak. While i'm driving it seems that it requires me to press the brake almost all the way down to get the car to come to a stop overall the brakes feel really weak. I took it to the dealer and they changed my brake pads, but after a weeks worth of driving they still feel the same.
A bit of history:my brakes were fine until i hit something on the road and cause me to blow a rear tire, obviously i know this caused the problem but i dont know whats wrong and the dealer said the change of brake pads is all it needed. Any suggestions what i should do next?
Change the brake fluid. Sometimes after time the hydraulic charateristic may break down. Now as you press the brake pedal the fluid may compress more before actually applying hydraulic pressure to the piston in yuor caliper. Over time your brake fluid also collects moisture through condensation and it too will build up in your lines causing poor hydraulic pressure. Also by changing the fluid you will rule out the possibility that there may be any air in the system. my .02
Re: weak brake problem
Re: Re: weak brake problem
Originally posted by hellas
you should have said that to the dealer. i'd look at brake lines
mada51589
05-03-2022 08:54 PM
