Water leaking into/under backseat...wtf
Old 02-01-2010, 01:15 PM
3rd Gear
tinklive's Avatar
ok this is getting very irritating, for weeks now i have noticed moisture between the back seat and bottom cushion (where the seatbelts come out) and i never could figure it out. Well i took the bottom part of the seat off and there was 1 to 2 cups of water sitting under the seat and the cushion was SOAKED. after the seat dried and I cleaned it (24hr period) I get in my car to start the rebuilding process and there is MORE water there. it did not rain the night before either. Then I saw its source ... As I was driving I had to slam on brakes and I saw where water gushed out from BEHIND the seat like it was coming from the trunk... but the trunk is dry..... somebody help me please....
Old 02-01-2010, 01:25 PM
'03 ABP YA4-S 6MT
rp_guy's Avatar
probably a plugged sunroof drain or a broken trunk seam.. either way pull all the carpet out of the trunk and diagnose from there
Old 02-01-2010, 01:46 PM
3.2TL
ThreePointTwoTeeEl's Avatar
Could be a leak in your rear glass. You might have to reseal the bottom of it.
Old 02-01-2010, 02:23 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Most likely a plugged sunroof drain.
Old 02-01-2010, 02:29 PM
I got the Shifts
phee's Avatar
info on plugged sunroof drain? i had water in my trunk and water in my seat
Old 02-01-2010, 02:45 PM
totaledTL's Avatar
Also check/replace tail light seals.
Old 02-01-2010, 03:32 PM
01 acura tl type s swap
m1k3y3.2tl's Avatar
my trunk did that so i took everthing out an found out when i blacked out my tail lights i guess you need new seals didnt now that had 3 in of water no lie i was pissed so check everything?
Old 02-01-2010, 06:28 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
there are 2 drains -iirc- in the sunroof track, open sunroof -stand on seat and look on top
or stand on stepstool next to the car
push a wire coat hanger thru there gently or compressed air often works
Look on seal edge of trunk for similar holes- also found on bottem of doors
do those for good measure
Old 08-10-2010, 03:35 PM
jayroc76's Avatar
I have the same issue. I replaced the rear tail light gaskets and im still getting a leak.
Old 08-10-2010, 06:49 PM
01tl4tl's Avatar
did you ck the sunroof drains?
and the trunk drains on the seal edge, and might be one in the lower well area - not sure on that one
Old 08-11-2010, 08:28 AM
jayroc76's Avatar
I checked the drain hose in the trunk which feeds to sunroof (seems ok). I can't seem to find the drain holes that start at the top of the sunroof.
Fortunately I have removed the plugs in the spare tire well allow for it to drain out. Temporary solution I guess.
Old 08-11-2010, 10:01 AM
I got the Shifts
phee's Avatar
I had the same issue. go into yor spare tire well and remove the drain plug. all the water in the spare area is going into your seat. that's why your rear is sagging too.
Old 08-11-2010, 10:33 AM
01tl4tl's Avatar
you have to blow low pressure compressed air thru the sunroof vent lines to be sure they are clear
Same with all the drain lines
or a wire rod like welding/brazing rod will work too- a gentle shoving
water is the last choice,, but it needs to pass the flow thru test
Old 08-11-2010, 11:09 AM
totaledTL's Avatar
Drain "seems ok"- you mean you just visually inspected it? Or verified it isn't blocked?
Mike734
12-10-2021 01:25 PM
IBankMouse
06-13-2020 12:53 PM
Avenger411
10-11-2015 03:53 PM
steve
09-30-2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: Water leaking into/under backseat...wtf
