Water leaking into/under backseat...wtf
ok this is getting very irritating, for weeks now i have noticed moisture between the back seat and bottom cushion (where the seatbelts come out) and i never could figure it out. Well i took the bottom part of the seat off and there was 1 to 2 cups of water sitting under the seat and the cushion was SOAKED. after the seat dried and I cleaned it (24hr period) I get in my car to start the rebuilding process and there is MORE water there. it did not rain the night before either. Then I saw its source ... As I was driving I had to slam on brakes and I saw where water gushed out from BEHIND the seat like it was coming from the trunk... but the trunk is dry..... somebody help me please....
Most likely a plugged sunroof drain.
01 acura tl type s swap
my trunk did that so i took everthing out an found out when i blacked out my tail lights i guess you need new seals didnt now that had 3 in of water no lie i was pissed so check everything?
there are 2 drains -iirc- in the sunroof track, open sunroof -stand on seat and look on top
or stand on stepstool next to the car
push a wire coat hanger thru there gently or compressed air often works
Look on seal edge of trunk for similar holes- also found on bottem of doors
do those for good measure
did you ck the sunroof drains?
and the trunk drains on the seal edge, and might be one in the lower well area - not sure on that one
I checked the drain hose in the trunk which feeds to sunroof (seems ok). I can't seem to find the drain holes that start at the top of the sunroof.
Fortunately I have removed the plugs in the spare tire well allow for it to drain out. Temporary solution I guess.
you have to blow low pressure compressed air thru the sunroof vent lines to be sure they are clear
Same with all the drain lines
or a wire rod like welding/brazing rod will work too- a gentle shoving
water is the last choice,, but it needs to pass the flow thru test
IBankMouse
06-13-2020 12:53 PM
