Wait this is confusing: 2003 TL Key transponder?
Old May 6, 2013 | 09:49 AM
lsiravi's Avatar
Hi
Recently bought a used 2003 3.2TL/Stype. It does NOT have a chip transponder. I had a key cut at the hardware store that works perfectly on the car.
However I keep reading that this model does have a transponder.
https://acurazine.com/forums/2g-tl-1999-2003-98/cost-replicate-key-775254/
Now, I am confused. Does the 2003 3.2TL have a key-transponder or not?
Thanks!
lsiRavi
Old May 6, 2013 | 11:19 AM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
Well, my 2002 TL-S certainly has a transponder key. How much did the store charge you to cut the key? Some stores can program the transponder part also, maybe they did that for you.
Old May 6, 2013 | 03:29 PM
lsiravi's Avatar
Duhh! I feel silly.
I guess when I tried the key without the transponder, I only tried *opening* the doors, never starting the car. I tried it today, and it wouldn't. So there.
*Places dunce cap on head and moves to the back of the class*
Old May 6, 2013 | 04:22 PM
Gabru678's Avatar
Can someone explain what you mean by transponder?
Old May 6, 2013 | 08:51 PM
Skirmich's Avatar
He means the Chip inside the Key ("Transponder")... He made a Copy of his Key without the Chip and thus could not start the car...
Funny thing is that it also should make the alarm go off.. Wierd that he could disable the Alarm but not turn the Engine, Perhaps he closed the car and opened before the Alarm could set becouse without a Chip the Alarm should also go-off even with the Key Cut.. The Chip also makes the Alarm de-activate.
Old May 6, 2013 | 09:03 PM
slvrblttypes's Avatar
the chip has nothing to do with the door just the switch. there is nothing in the door to read a chip on our cars.
Old May 6, 2013 | 09:20 PM
Skirmich's Avatar
You know chips dont have that Small frequency range right? There is NOTHING in the Door to read the Chip in our Cars... But that doesnt mean it does not do so from the Ignition Switch too...
Never tried it since I dont have a Copy of my Key without Chip but Im pretty sure Unlocking the Car from the Key Hole also makes the Chip negotiate with the Ignition to Remove the Alarm.. Otherwise if I had any Key I could do the Key Hole trick and Unlock the Car and the Alarm in the Process.. Would be pretty weak Design Flaw.
Old May 6, 2013 | 10:17 PM
all the chip has to do with is the switch. the immobilizer disables the fuel if you try to start without chipped and programmed key. yes it is a weak security system.
Old May 6, 2013 | 10:42 PM
Edward'TLS's Avatar
6G TLX-S
There is a switch inside each of the two door lock cylinders, to detect the key position. This key position info is fed to the security module to arm or disarm the security system.
As long as the key (chipped or non-chipped) turns the door lock to the unlock position, the switch will send the key_unlock signal to the module to disarm the system.
The chip-reading range of the ignition sensor is very limited. The chipped key has to be right up against the ignition switch in order to be read properly.
Old May 7, 2013 | 07:49 AM
AlanW's Avatar
I agree, a cut but unprogramed key can open the door locks, and a keyless remote can be programed to open & lock the doors without the transponder key. It's when you go to actually start the car....
Mike734
Dec 10, 2021 01:25 PM
soupi
14
Nov 15, 2015 11:15 AM
Jimmy_D
Oct 7, 2015 11:52 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
malvothegreat
Sep 29, 2015 12:38 AM
