VSA Lights Blinking ??
Does anyone know what it means when the VSA light is blinking while you step on the gas. I was driving tonight and at a stop light, I gased my TLS and the tires slipped a bit cause the ground was wet after the rain. Then I notice my VSA lights blinking while I was slipping. Should I be concerned about this or is this just the VSA doing it's work?
The blinking VSA orange triangle with the exclamation point means the VSA is currently actively engaged in trying to keep the car under control. It will occur if you floor the accelerator or otherwise cause the front tires to lose traction. It is working properly.
<B>"ow you know why extra horspower in a two wheel drive car has diminishing returns off the line."</B>
Beacause of the he blinking VSA orange triangle with the exclamation point?
yeah i'm bored.
Originally posted by stiletto
<B>"Beacause of the he blinking VSA orange triangle with the exclamation point?
when the vsa blinks(the ! light) it engaging!
it happens when you floor the gas causing tires to spin. Or when in the snow and ur tires are losing traction.
and when it blinks along with the d5, you in deep sh*t!
mada51589
05-03-2022 08:54 PM
