vibration while in gear and brake applied
Old Nov 20, 2009 | 10:22 AM
JoshuaStetler's Avatar
7th Gear
I'm not sure how to explain it but ill try .....In park or neutral it seems fine but when I'm at a stop light my 99 acrura tl vibrates.
I have tried to jack the car up to see if it was a load thing but when in the air the wheels are turning and when I apply the brake it starts vibrating, but when i let off it stops and its fine ,now ive changed all motor and tranny mounts except for the 2 $150 ones but they seem fine ......any geusses would be great thanks in advance...
Old Nov 20, 2009 | 10:34 AM
gold2003tl (90)'s Avatar
2003 TL-p
do you have a slightly high idle?
Old Nov 20, 2009 | 10:38 AM
7th Gear
idle is only high for a few minutes at start up but sits at 700 to 800 normally
high i mean 1000 to 1200
Old Nov 20, 2009 | 10:56 AM
2003 TL-p
hmm, check the tension of your throttle cables, they my be just a tad bit too tight and its not letting the TB plate close all the way, or its not letting it close freely.
i had this problem, i loosened the cables up just a tad, and i have a normal idle - 600 rpms
Old Nov 20, 2009 | 10:58 AM
thisisnotdave's Avatar
Porkchop Sandwiches!
How many miles do you have on the mounts? They usually don't last past 60k so I'd check them again, I had terrible vibrations at idle in gear until i changed them.
Old Nov 20, 2009 | 11:03 AM
7th Gear
Im assuming your refering to the 2 big ones that have the vacuum lines to them .... im not to sure how old they are i recently bought this car and some minor issues have come up but right now its the vibration and visually they look fine but there is always the chance they are bad.is ther any way other than visual to check them?
Old Nov 20, 2009 | 11:05 AM
7th Gear
thanks ill have to try that for the idle they seem to be a bit sticky
Old Nov 20, 2009 | 11:23 AM
my.daily'tl''s Avatar
Always Working In
The mounts are really hard to look and tell if they're bad. You would have to do the foot on brake and go through gears while someone looks under the hood for any engine movement. I have all new mounts. Just changed the rear. As soon as I took it out fluid leaked out really good so it was shot but I couldn't tell by looking at it. When I did the front it opened up like a can of soda! Again didn't know till they came out. If I were you I'd seafoam it up too! Oh and the front is about $80 and the rear was $130 from acuraoemparts.com. I know it sucks to have a tl that isn't sewing machine smooth.
Old Nov 20, 2009 | 11:29 AM
7th Gear
ya its a pain trying to figure where its coming from but ill try to go with the mounts for now and see what anyone else says to narrow it down more thanks.
Old Nov 20, 2009 | 12:47 PM
01tl4tl's Avatar
that sounds like a front mount- the front usually goes sometime after 50k miles and then the right side fails if the front not fixed soon.. usually found with trans failure - first time anyone looked at the mounts
Others failing would mean the front broke a long time ago and the others had to take that load and failed
Yes they are expensive- and fluid filled- and some years have a vacuum boost line to them so they tighhten up on full throttle--cooool man~
One of those fails and you get a mystery vac leak too
put the car on ramps and look UP at the front-rear mounts for a fluid leak-dust stuck in a funny line to side or bottem of mount,, very small drips on garage floor of strange oil like no other you have seen
Our cars lack an upper engine torque bar so the mounts take a beating.. especially if you thrash
Old Nov 20, 2009 | 12:53 PM
7th Gear
That is my thoughts and i just realized that it doesnt happen in reverse only drive and as for the tranny it shifts just fine aside from needing new fluid and a screen cleaning. BTW this tl has 151000 miles on it.
Old Nov 20, 2009 | 01:08 PM
7th Gear
Are there any after market bars that i can put on? i work at a welding shop so im assuming i can put one on but wondering if there is an oem part
i also drive it pretty soft considering other issues that need fixed and soon as money shows up that can happen but trying to do the minor things now.
Old Nov 20, 2009 | 06:57 PM
01tl4tl's Avatar
no- no add on torque bars for the TL that I am aware of
Stuck with the problem as long as you own a TL
Its a cruiser not a road abuser
Old Nov 20, 2009 | 08:36 PM
FirePR2002's Avatar
bringin lead
^^haha - is the music too loud for you too?
Old Nov 21, 2009 | 12:59 AM
01tl4tl's Avatar
the TL is my Bose equipped baby- SS suspension and edfc for comfort
the Shadow 1100 v-twin is my asphalt abuser,, and it makes its own beautiful music~
mada51589
Jan 9, 2025 04:40 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
jliu6789
Sep 8, 2015 08:02 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
