Vibration in steering wheel
Old Feb 7, 2006 | 08:17 AM
briguyiu's Avatar
I just picked up a 2000 TL with 59K miles and I get a slight vibration in the steering wheel when I'm in idle at a stop light or braked in D5. The RPM's don't fluctuate and are at a 750RPM constantly. I just wanted to know if this is normal. In my previous car I didn't get any vibration at all. It may just be the vibration of the engine, but should I be feeling that, or should I take it in to get checked out. I can barely feel this vibration in the drivers seat as well.
Old Feb 7, 2006 | 02:17 PM
Acuracy02's Avatar
運転することを愛
If your engine is running there is going to be a slight slight feel of that through the whole car. Basically you can tell your car is running. If the steering wheel is actually vibrating to the point where you can see it moving back and forth while you are stopped then that might be an engine mount, but that would most likely take affect on daily driving as well. Try to describe further.. Maybe someone else can offer advice beyond this...
Old Feb 7, 2006 | 02:59 PM
bkzjimmy's Avatar
NiGhT rIdEr
try changin all ya fluids and filters. mine shakes but im almost positive my intake manifold is filthy.
Old Feb 7, 2006 | 03:40 PM
briguyiu's Avatar
Its more like you described acuracy...you cannot see the steering wheel vibrate, so I guess all is well. I will change the fluids and filters anyway though
Old Feb 9, 2006 | 10:52 AM
whatwasthat's Avatar
yuup, mine is vibrating too - but it's b/c i need an oil change. it's now 7k miles since the last one.
Old Feb 10, 2006 | 09:02 AM
Acuracy02's Avatar
運転することを愛
If my steering wheel vibrated because I hadn't changed my oil I would be pissing myself. I doubt that is your cause....otherwise your engine is about to seize.
Old Feb 10, 2006 | 08:04 PM
ou sig's Avatar
Boomer SOONER
not changing your oil in 7k miles has nothing to do with your wheel vibrating. most likely an engine mount cause these engines should idle silky smooth if everything is working as it should
Old Feb 11, 2006 | 07:07 PM
zibadun's Avatar
I have this problem as well. It's pretty annoying.
Assuming it's an engine mount, how expensive is it to fix? If under a grand I might have to just bite the bullet.
Old Feb 11, 2006 | 09:53 PM
thAviEtbOi 37's Avatar
had the same problem, never noticed it since i brought my car like that, but after replacing my engine mount, the problem disappeared.
Old Feb 12, 2006 | 10:13 AM
ou sig's Avatar
Boomer SOONER
there are a few different mounts, all can be replaced for well under a grand
http://www.acuraautomotiveparts.org/...prddisplay.jsp
Old Feb 13, 2006 | 07:20 AM
briguyiu's Avatar
So if it was vibrating while driving it would be an engine mount, but since it is only during idle and not bad enough to actually the wheel vibrating its just the engine...correct?
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
04tler
Sep 10, 2015 04:03 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
