using power steering fluid to flush engine
Old Feb 29, 2008 | 07:07 PM
1st timer's Avatar
UB6IB9
I read on the net that someone adds 5-10% power steering fluid to the crank case about 50 miles before an oil change. He claims that hydraulic steering oil is full of dopes that are able to clean small holes (essential in power steering systems) and when draining the oil 50 km later all dirt is leaving in the old oil. What do you guys think?
Old Feb 29, 2008 | 07:17 PM
mrempp's Avatar
I would just use seafoam, it's meant to go in your crankcase unlike the P.S. Fluid. Put it in right before an oil change, let it run for a few minutes then change your oil. or put it in before you drive to an oil change place.
Old Feb 29, 2008 | 08:44 PM
mcflyguy24's Avatar
If you seafoam the crankcase your gonna wanna run your car hard or rev it really high for a good bit for it to work it's magic and so that it doesn't foul your plugs, which sometimes can happen. I don't the PS fluid is a good idea. Seafoam is for cleaning dirt and carbon deposits out of your engine not PS.
Old Feb 29, 2008 | 09:31 PM
FirePR2002's Avatar
bringin lead
Crankcase=oil fill hole - you're thinking through the vac line or throttle body.
Old Feb 29, 2008 | 09:45 PM
01tl4tl's Avatar
seafoam in the oil has nothing at all to do with the spark plugs!!
And the fouling issue is only if you have old dead sparkplugs and dont do the burn off drive after seafoaming the Intake Manifold system
Stop listening to your friends who saw something on the net, and believe the folks that live and breathe acura information
Old Mar 1, 2008 | 12:03 AM
1st timer's Avatar
UB6IB9
I read everywhere that doing an engine flush can harm your engine,if you'd like to clean your engine,do frequent oil changes.It takes longer to do but is safer for your engine.
Old Mar 1, 2008 | 03:54 AM
01tl4tl's Avatar
If we were talking about your old 1973 shitebox there may be an issue with cleaning the engine internals.
The testing by azine members spans hundreds of thousands of miles of expereince and we often clean the engine out with every oil change every 7500 miles.
Cumbustion byproducts do not all get picked up by the oil and deposited in the filter
Cleaning of the very small oil passageways in an Acura engine results in LONGER lifespan~
Believe the general populaus at large, or a bunch of acrua nuts??? your choice
Old Mar 1, 2008 | 06:42 AM
1st timer's Avatar
UB6IB9
I'm not doubting the anyone ,just trying to see what options there is out there.
Old Mar 1, 2008 | 09:02 AM
hellas's Avatar
i know a lot of guys that put ps fluid in, run the engine for a bit, then drain. I think its more of an old school thing
although, when they say ps fluid, they are refering to trans fluid (dexron 3). The majority of cars use trans fluid for ps fluid
Old Mar 1, 2008 | 09:06 AM
thisisnotdave's Avatar
Porkchop Sandwiches!
to all the seafoam guys. I wouldnt trust any other "flush" or cleaner in my car, that stuff has been used for as long as engines have been burning dead dinosaur juice, it works and its safel.
Old Mar 1, 2008 | 11:33 AM
1st timer's Avatar
UB6IB9
what stuff are you referring to ?
Old Mar 1, 2008 | 11:38 AM
01tl4tl's Avatar
Seafoam a redily available addative that sells for 6-7 usd per pint-8 oz, white colored can. See the DIY section for instructions- skip to the last page for newest method.
You can use it direct into the engine oil before change or the gas tank or an intake manifold vac port to get it right at the valves and piston tops.
TL-Rocket
Apr 29, 2023 02:33 AM
mike from annapolis
May 7, 2017 08:21 PM
Sep 14, 2015 03:16 PM
nash3222
Sep 10, 2015 09:46 PM
