urgent help needed
Originally posted by AndySara
BTW...try this:
The multiplex unit is a small blue box on passanger side located on the back of the fuse box.
BTW...try this:
Let us try this again:
There are 3 separate CPUs that control various warning systems, illumination intensity, intermittent wipers, power windows, the remote control security system, auto headlight system for the 2003 TL's. The communication between the CPUs is via a multiplex data unit.
If you are having a problem, it might be due to one of the CPU's malfunctioning, not the mulitplex unit.
For other forum members to help you, can you describe what kind of problem you are having (or what you intend to do)...and what year car you are driving ??
the passenger multiplex unit is on the inside part of the passenger fusebox. i think it is an off white color. if you are sitting in the front passengers door area looking at the fusebox. i think it is about the size of 2 packs of cigarette boxes put side by side, or maybe alittle bit smaller.
The passenger's multiplex control unit is located at the righ end of the dash. You may want to remove the glove box to see it.
Once removed the glove box, you should see a box with the label up side down (if i remember correctly)
TLDude876
12-28-2016 03:18 PM
2015TLX
09-11-2015 02:56 PM
nuldabz
09-03-2015 05:49 PM
