UR Crank Pulley installed....
#41
Purchased: April 28, 2001
Originally Posted by Excelerate
Actually in the instructions Unorthodox Racing says to wait for about 5 days for the ECU to adjust for the new crank pulley in order to notice the gains. If anyone is interested in purchasing this crank pulley check my signature for a link to a Special Pricing Event.
Josh
Excelerate LLC
Josh
Excelerate LLC
Hey Josh...I'm new to the "pulley-scene" so please bear with me. My question is when installing the crank pulley, would it be more economical to change it at the same time I change my timing belt?
Reason being is that if the timing belt directly affects the crank pulley, wouldn't it make sense to do them both at once to save $$$ on labor? Just like changing springs & shocks is actually cheaper than swapping springs alone?
I'd appreciate if someone can clue me in since my 100k mile tune up is around the corner.
#42
#43
Originally Posted by El pana/TL32
Yes, you would save on labor, if you are due for a timing belt replacement. Get them both done and stick with the recomended Gates belts for the pulley. You are going to love the performance gains and quicker rev improvement. Get your transmission flush while you at it.
Well the plan is to have a new tranny around 95k miles, so no need of a tranny flush. As for the "Gates belts"...I take it that's NOT the OEM belt, but the belt that comes with the UR crank pulley?
#44
#45
Former Sponsor
Josh
Excelerate LLC
#46
I just wanted to update the board memeber that to date, I have no issues with my UR Crank Pulley. My belts squeek sometimes, but otherwise, everything is ok.
I would like to hear from those members with longer install time, and reporting no problems with the crank pulley.
1. El pana/TL32: UR Crank pulley installed 10/20/2004 no problems to date.
#47
UR is a good pulley. You shouldnt run into problems.
#50
Sippy Cup (x2)
#51
It did not squeak before the install. And yes, I did have the belt tension checked after installing the UR pulleys, and it was ok for a while, and couple weeks after the squeaking came back. Maybe we have to play around with diffrent belts and keep adjusting them?
#52
Sippy Cup (x2)
#53
Sippy Cup (x2)
Just finished installing the pulleys. I did the Ultra SS set. Install wasn't to bad. The impact wrench definitely makes life a lot easier. I still had problems with the crank pulley though. I ended up putting a breaker bar on there and wedging it up against the frame of the car and gave the key a little tap so it engaged the starter, but did not actually start the car. Worked like a charm. Other than that, everything went very smoothly. The car seems to start easier now and feels more responsive but I don't know that I can really feel a hp gain in the seat of the pants meter. I will be taking it to a dyno soon...that will tell me my gains. This will be the only mod I've done since my last dyno so I am anxious to see how it turns out.
#54
I need 2 more gears
reset your ECU and take your car for 15-20mins spirited run hitting v-tec often and WOT often and you will start to feel your car pulling harder and getting into higher rpm's faster. I know my car gets to 5k in a sec. after I stomp on it and pulls very hard.
#55
Good work on the install Very curious to see the dyno as well Report back to us! Good work and enjoy!
#56
Show me da MONEY
I was actually thinking about trying this, jacking up the car with breaker bar attached to the bolt and the handle against the floor, then slowly letting the car down. I figure the weight of the car would get that bolt off or break the bar.
#57
No body kit for me...
I would also be inerested in hearing from anyone who has installed the crank pulley themseleves. UR's directions of "follow factory service manual" does not help me much
Thanks,
Paul
Thanks,
Paul
#58
Sippy Cup (x2)
Originally Posted by muffaburn
That was a pretty smart way of getting the bolt off, with what and how did you torque it back with though? and what setting? I have had my crank pulley sitting in my closet for months and what it installed but have heard the bolt is a bitch to get off. I can get it installed professionally for about $115 but would rather do it myself if I can, and have the proper tools.
#59
Sippy Cup (x2)
Thanks,
Paul
Thanks,
Paul
#60
Sippy Cup (x2)
#63
S E L L
Originally Posted by climberbry
Yes, you read that right, my blower motor has burned up and now my belts squeak all the time.
2000 TL
2000 TL
acuratl26
04-23-2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
