Uneven Exhaust
Old Jul 23, 2002 | 10:25 AM
joneschop's Avatar
Uneven Exhaust
The right rear tail pipe appears to be lowewr than the left one on my 03 TLS. Anyone else experience this problem? I am taking to the dealer this week, but just wondering?
Old Jul 23, 2002 | 10:50 AM
hangman's Avatar
same thing on my car..
Old Jul 23, 2002 | 11:04 AM
paxus's Avatar
Re: Uneven Exhaust
Is this problem purely aesthetic? And how much lower is the right tail pipe? 2 inches or more?
Oh, and do our TL-Ss have dual exhaust, or just two tail pipes?
Old Jul 23, 2002 | 11:34 AM
Kramer's Avatar
Re: Uneven Exhaust
My '01 had and my '03 has the same problem. I don't think the dealer will do anything about it.
Old Jul 23, 2002 | 02:15 PM
SergeyM's Avatar
15 minute fix
My 2002 had the same problem. Took my dealer (Wayne Acura, NJ) about 15 minutes to alligned the pipes. They also fixed mis-alligned steering wheel air bag cover.
Old Jul 23, 2002 | 04:01 PM
rock's Avatar
I have seen several TLs around with uneven tail pipes, including mine. I'm not sure how the dealer will fix this, but a radiator hose clamp worked well for me. I think some other people were using zip ties.
Old Jul 23, 2002 | 05:25 PM
TLS RULZ's Avatar
I had the same problem with mine... Took it to the dealer during an Oil change and they adjusted it... Then it returned after 3-4days... Mine right was 1.5 lower and 0.75 towards the left (looking from the rear).
Then when I went in for the 25,000kms service ... I mentioned it again... This time they loosened the whole exhaust and adjusted it... Its now 30,000 and its still pretty level...
So. if you are persistent the dealer CAN adjust it for you.
TLS RULZ.
Old Jul 23, 2002 | 07:50 PM
Xorg's Avatar
First off - do NOT use a plastic tie, it will just burn off!
Mine was off when I picked my car up, dealer fixed it on the spot.
My pipes are both level, but the right one seems to creep into the middle about an inch or so between services - and each time the dealer fixes the problem to perfection.
joflewbyu2
Oct 8, 2015 11:16 AM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
ivan06106
Sep 26, 2015 04:38 PM
Brandle34
Sep 23, 2015 07:20 PM
