two questions
Old Dec 15, 2009 | 11:24 PM
taintedplay's Avatar
two questions
ok, i know our 1/4th mile was 14s, but whats our 0-60stock?
also, i have been using 87octane gas, would it make a good difference to move up?
Old Dec 16, 2009 | 12:10 AM
brown_lad's Avatar
Yes , you definately have to move up on the gas . Only 91 is recommended for our cars ...
Old Dec 16, 2009 | 12:55 AM
hANDYcaptd's Avatar
It's the Halladay season!
I believe the Type S was 6.2
Old Dec 16, 2009 | 01:40 AM
nayaab88's Avatar
I ONLY fill up 93... that's the way to go... I dunno about others, but I personally can feel the difference in the car when a lower grade of gas is filled.
Old Dec 16, 2009 | 02:35 AM
jaMezBOI's Avatar
philly flickin'
My cars only seen 94.
I also notice a difference in performance with lower octane gas.
Old Dec 16, 2009 | 03:04 AM
JterrorC's Avatar
Always a Honda =Þ
hav yous.....since i bout the car its been vpower by sheel 93....ima go to those water down shyts n see whats the diff
Old Dec 16, 2009 | 03:26 AM
01tl4tl's Avatar
the car requires 91 or 93-94 if thats what they sell in your area
Since its been run on 87 there will be excess carbon loading of the valves and pistons!
Throw a can of seafoam in 1/2 tank gas and another can in the intake main vac port at the TB connection to intake manifold- see DIY section
Will clean all the crud out and restore like new performance~
Probably needs new sparkplugs too- NGK Iridium or NGK Iridium IX
87 is a killer on high compression engine- yes the computer will compensate by retarding timing- leading to other problems
Old Dec 16, 2009 | 04:28 AM
Rajca's Avatar
wham bam thank you ma'am
^x2. dont go cheap with this car or it will bite u in the ass. i was using 89 in my tl-p. never drove it hard. did feel an acceleration drop downgrading to lower octane. if u have an s i wouldnt go lower then 91
Old Dec 16, 2009 | 07:02 AM
fsttyms1's Avatar
Yes, use 91. There is no reason not to use it. It costs you all of 2 bucks or less more to use it and is what the car was designed to use.
Also the quarter was 15's and you wont achieve those numbers with 87
Old Dec 16, 2009 | 08:02 AM
im not racing, someone just asked me the 0-60 and i wanted to say atelat a semi acurate number.
should i seafoam before i put in the better gas?
also, can i just add it in, or would them mixing somehow hurt the engine?
Old Dec 16, 2009 | 09:27 AM
Rajca's Avatar
Put the 91 in and drive around till ur at about 1/4 tank. Then put some seafoam
Old Dec 16, 2009 | 11:03 AM
01tl4tl's Avatar
-max seafoam use for driving method is: 2 ounces per gallon of gas (more is not more effective- per seafoam)
thats 1 can to just under 1/2 tank
may want to repeat that in a month, and/or do the intake vac method twice as well- then good for a year
very simple DIY and acts instantly, while gas method takes days
you still need to do the gas method to clean fuel sprayers from the inside even if you do the intake vac
Old Dec 16, 2009 | 03:19 PM
niju321's Avatar
https://acurazine.com/forums/2g-tl-1999-2003-98/1999-tl-stats-0-60-max-speed-518913/
Old Dec 16, 2009 | 03:26 PM
speedemon90's Avatar
This explains my situation. Ive had the car for only like a year and a half, but my parents never filled 91. 89 for the first couple years and then 87. And they have me fill 87 too. Ive ran dynolicious on my iphone, the best ive gotten is 8.2 seconds. I have a 00tl, with 165,000 miles and its stock. Tires may also slow it down, I dunno really how my tires are compared to others. I have fuzion HRi. But my tl should be doing mid 7's if it was brand new/stock. So im a ltl off.
Old Dec 16, 2009 | 03:43 PM
niju321's Avatar
the gas you're using probably isn't helping when you're at max load like an acceleration run
Old Dec 16, 2009 | 05:20 PM
that says with a tl. im looking for TLS.
ok, so fill with 91, drive tell its at a quarter tank, then do the seafoam diy. wheres a good place to buy seafoam
Old Dec 16, 2009 | 05:48 PM
friesm2000's Avatar
B A N N E D
91 is all we got here that is readily available
Old Dec 16, 2009 | 06:07 PM
01tl4tl's Avatar
seafoam is available at most parts stores- walmart etc
8-10 bucks a can
Please dont use more than 2 ounces per gallon of gas - throwing away your money.
thats 1 can in 1/2 tank!
Old Dec 16, 2009 | 08:35 PM
DaveS221's Avatar
and edmunds says that a tlp shud do 7.7 0-60. type-s shud do 6.58.
http://www.edmunds.com/used/2000/acu...648/specs.html
http://www.edmunds.com/used/2002/acu...218/specs.html
Old Dec 16, 2009 | 08:37 PM
DaveS221's Avatar
whoooaaaa for real??? i was thinkin bout movin to colorado but i didn't know they have cali gas... thought only cali had cali gas. over here iv seen 93 in every state on the east coast for the most part. sorry to hear bout the 91.
Old Dec 16, 2009 | 08:45 PM
friesm2000's Avatar
B A N N E D
yeah geneally the further you go west the more often you only see 91 as the highest, but there is a place right near me that does sell 100 octane street legal gas, but the next place that sells that, is like a 100 miles away, so not really readily available
also the altitude sucks for actually making power (we are down like 15-20% on HP here [a mile high])
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
