Two Noises That Are Killing Me
Hi all...
Well, with a lot of effort, I have been able to eliminate most of my squeaks and rattles... Two remain...at least these are the two that I can hear now:
1. Metallic vibration coming from around the dashboard... I can hear it when the car is vibrating slightly, and sometimes on bumps...
2. Noise from door... Sounds like the weather stripping is not doing it's job... I hear noise in the upper area of the car when I drive with my left ear... Sounds like it's coming from the upper corner of the door (right by my ear)...
Anyone report similar noises (and more importantly...any solutions)?
Thanks!
Mike
Thanks!
Mike
Dash?
door, make sure that the little rubber trim is seated all the way corectly. I was cleaning mine one day and accidentally misaligned part of it and caused it to sound like a misaligned door/airleak
Originally Posted by fsttyms1
Dash?
The rubber trim appears to be aligned... Not sure what I would look for except for something obvious (which I cannot see anything that looks obviously wrong)...
Thanks...
Ill try to take a pic of mine in the AM (when its light out) and show you where mine was off
Boomer SOONER
I have this annoying noise from my driver side pillar also - a rattle and I cant find anything that could do it. I took off the pieces and checked the bolts that hold seat belt on and the noise is still there...who knows
I have the same problem with my doors. Noise seems to be coming from the top part of the window from both front doors. It sounds like metal hitting metal and I only hear it when going at highway speeds. Been having this problem for about 6 months and its the only thing that pisses me off about this car. Hope someone has better luck in finding the source of this problem..
As far as the metallic noises that (seem to) come from your dash, try centering the steering wheel and then slapping it with your fingers at both 3 o'clock and 9 o'clock (slap the outside edge of the steering wheel). If you hear a noise, is that it?
Don't have a solution, just something my car does that I recently pinpointed. If it applies to you, and you have a fix, please post.
WNC Real Estate Sales99TL
I have the door noise as well. The dealer replaced the door trim entirely and also lubed the weather strip, but nothing helped. But If i lower the window just tiny bit, then the noise is completely gone. Sucks that Acura can't even design a door that closes like Audi or Bmws
Originally Posted by MikeekiM
Hi all...
Thanks!
Mike
Thanks!
Mike
Originally Posted by tlling
I had the same problem the noise by your ear is coming from the drivers seat belt unit. After several trips to the dealer they finally got it right but it took the following: Replace seat belt, lube seat belt mechanism and isulate the trim piece that covers the seat belt harness on the door pillar. I also was getting noise from the drivers door panel right by the area were the door lock is at and the wood trim in my door pane. They after several attempts replace part of the door panel and it took care of it.
I know...why fix something you can't hear, right? I don't want my car to sound like a cheap POS... So if I know the noise would be there for the passenger, I'd want it fixed...
Guess I'll see if a friend can help me listen for it...
FYI - I am making an appointment to have these two problems looked at by the dealership... I'll let you all know what they find... (won't be for a week or so... I left a message for my service advisor this evening to set up an appointment)...
I'll have to mention this when I bring my car in... Maybe they can insulate the steering column with some foam insulation...might do the trick...
Update: Just dropped my car off at the dealership for warranty work...
We were able to duplicate both sounds... I'll let you know how it goes!
It'll take at least a week to give you guys an update though... I am on business travel next week, so I won't be able to confirm anything until I get back...
Wish me luck!
Wish me luck!
do you have a OEM kit on your car? i was searching all over for this noise in the right dash and it would only happen on freeway speeds. afer all the time wasted on finding out what it was, it turned out that one of the clips that hold the side skirt in place. it looked like a black plastic push in clip. i fixed it by adding a washer in between the clip and side skirt bracket. i only noticed the noise when i had the radio down. usually the radio is turned up in my car
Boomer SOONER
I found out what makes the noise right by your ear when you drive...its the seat belt mechanism at the bottom of the pillar. I took off the inside plastic to show the metal and the seat belt gear. all that noise what coming from the seat belt gear not being 100% tight. when the car is stopped, I can make that noise by slightly moving the seat belt gear side to side. I guess that noise just gets echoed up the inside of the pillar so it is loud right by your ear. Im going to try to get rid of the noise finally tomorrow.
Boomer SOONER
Originally Posted by Luke7
Any tips on removing the trim? I hate breaking clips I don't know about?
Apparently it was coming from a loose screw... He's tightened it and thinks that my steering wheel noise has been eliminated... I won't be able to confirm it myself until I pick up my car late next week... But thought I would let you know...
Thanks for pointing this out mblanton66... It was a critical piece of information going into the dealership and being able to point this out...
Alright guys... They finished earlier than they planned, so I was able to pick my car up before my business trip...
Problems appear to be resolved... The metallic vibration was from a loose screw near the airbag assembly... The service tech told me that he tightened it down, and applied some locktite to the threads (so that should be solved for good)...
The noise near my left ear was caused by the seal that the window/glass presses up against... Not the rubber gasket around the door that I thought was causing it...
I still hear slight noises...but nowhere near the noises that were there before... I think the remaining noise is probably categorized as "normal" cabin noise though...
I removed the trim on the pillar between the front and rear door. It comes right off and also went back on very easily. I unbolted the seat belt mechanism. Yea, that what was making the metal vibrating/rattling noise. I put some silicon (have a tube of it that I used on brake caliper guide pins) on the metal clip that holds tension on the seat belt locking mechanism and also sprayed some liquid silicone into the gear mechanism. It doesn't raddle anymore. It was an easy fix for a real annoying noise. YEA!
Moderator Alumnus
I have the same problem in my car with the noise like swooshing air next to my left ear. Drives me crazy. The voices in my head keep telling me the window is open
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
