Two bulbs at the same time?
Old Feb 27, 2009 | 11:40 AM
igoyuk1's Avatar
Cool Two bulbs at the same time?
Hi All, I read through the forums and it looks like the headlight bulb replacement issues was already thoroughly covered. One part I am not clean on:
My passenger side low bean is out. Assuming its just the bulb, how important is it to change the bulb on both the driver and passenger side at the same time? I know that it is preferable to do both, but this car is already almost 9 years old (2001) and I want to avoid spending $100 on a working light bulb. Thanks
Old Feb 27, 2009 | 11:47 AM
Shocker0316's Avatar
you can buy pairs of bulbs for around $50 on the internet... you will d2r bulbs
Old Feb 27, 2009 | 11:49 AM
igoyuk1's Avatar
I looked around, couldn't find HID bulbs for under $100...do you know of a good site?
Old Feb 27, 2009 | 11:53 AM
ZEUS'O3TL's Avatar
Low & Slow w/Dubz On My
check ebay....put in D2R in the search and go with Phillips....our vendor here Excelerate sells the Kaixen and thats another good brand....its also important to change both of them becuz one bulb will be much brighter than the other one
Old Feb 27, 2009 | 11:55 AM
Rockstar21's Avatar
The Dumb One
i saw single bulbs for 35 bucks on the first page i searched.
of course i would go with a known brand, but still like mentioned.. you can find pairs for 50.
those bulbs are normally WAY overpriced. which is why you can find them so cheap online
Old Feb 27, 2009 | 12:20 PM
TLin401's Avatar
'13 Hyundai Sonata
Always change bulbs in pairs.
Old Feb 27, 2009 | 12:41 PM
bonknhead's Avatar
I changed my original 4300k D2R bulbs with 4300k D2R Phillips bulbs I bought from eBay for $80 shipped last March. I remember when I replaced the first one that I turned on the headlights on to check if I installed it correctly and there was a big difference between the brightness of the new vs. that of the old.
Old Feb 27, 2009 | 01:11 PM
igoyuk1's Avatar
Thanks a lot guys!... Now comes the fun part, figuring out it the bulb is the problem and replacing it.
Old Feb 27, 2009 | 02:37 PM
01tl4tl's Avatar
if you get pink tint on startup of light- thats the death warning
So is flikker or sudden drop in brightness
Most of the 2000 -2003 cars have 2500-3000 hours on the bulbs now and its getting to failure time
Its not a waste of money to be able to see like you cant believe!!
4300k is stock color, 5000k more blue with good white on road- 6000k is more blue less white,,anything higher is really hard to see stuff on the road
Old Feb 27, 2009 | 02:38 PM
01tl4tl's Avatar
If you get moisture inside the headlight lens, you must fix that soon and replace the bulbs after
Old Feb 27, 2009 | 02:52 PM
fsttyms1's Avatar
Always replace bulbs in pairs. Even standard halogen.
Old Feb 27, 2009 | 02:57 PM
gold2003tl (90)'s Avatar
2003 TL-p
i will be getting 6000k for my low beams, i suggest to do the same
Old Feb 27, 2009 | 06:58 PM
01tl4tl's Avatar
I have 6000 and wish I had gotten the 5000s as planned, but somehow had 6 on the brain when placing order and mistyped--doh~
More useable light on the road surface is important
Old Feb 27, 2009 | 07:01 PM
01tl4tl's Avatar
replace bulbs in pairs goes for brake lights and turn signal bulbs too--
the TL will last about a month before the other side brake light goes out and you have to repeat the inner trunk panel loosening
Replace the 4 brake-turn bulbs at one time and be done with,, it is my opine
Old Feb 27, 2009 | 08:18 PM
Rockstar21's Avatar
The Dumb One
i kinna like that my bulbs are offset in the headlights as far as when they were installed... it saves money when one burns out. i have a 3 yr. old bulb and a 5 month old bulb.. when the old one burns up.. 40 bucks. 10 min. job. done
oo7spy
Jun 19, 2023 12:48 AM
pozebly
Sep 23, 2015 07:30 AM
forrie
Sep 15, 2015 09:57 AM
theinsvnity
Sep 10, 2015 10:22 PM
Mcj270
Aug 31, 2015 04:45 PM
