tune ups before the races
Old Sep 3, 2008 | 04:46 PM
thinhthan's Avatar
what tune ups should i do before the races. i know i should change oil, spark plugs, should i seafoam? i might do a k&n air filter to
Old Sep 3, 2008 | 05:57 PM
fsttyms1's Avatar
Run what you brung.. I wouldnt do any thing special. Maybe change the oil but thats it.
Old Sep 3, 2008 | 06:45 PM
Edward'TLS's Avatar
6G TLX-S
Tires -> change to super sticky track tires.
Old Sep 3, 2008 | 06:49 PM
CL-Slick's Avatar
Chillin' in my trailer
Oil, and make sure your tranny fluid is good.
Old Sep 3, 2008 | 06:58 PM
ChrisQ1980's Avatar
hates the winter
Take out your spare, and tools, get rid of unnecessary stuff inside the car. Wash and wax it to keep rubber/track dirt off the paint. Make sure all your fluids are full and clean. Make sure your brakes are good as well.
What type of racing? 1/4, autocross, HPDE?
Old Sep 3, 2008 | 08:25 PM
Rajca's Avatar
wham bam thank you ma'am
what kind of car and what do u have done to it?. take out anything that u dont need, all it is dead weight and it will lower your times, if your pushing a lot of power, be sure to use slicks,
Old Sep 3, 2008 | 08:35 PM
thinhthan's Avatar
i have a all stock 99 tl-p. last time i was at the track i ran 17.4 i got that time 3 times i ran. i thought the tl was suppose to be faster. im racing 1/4 mile
Old Sep 3, 2008 | 08:38 PM
Rajca's Avatar
should be around mid 15 sec. i ran 14.95 twice with an 02tl-s, stock tires, intake resonator removed and k&n filter, removed the spare tire and tools as well.
Old Sep 3, 2008 | 09:04 PM
phee's Avatar
I got the Shifts
99 TLP should not be that slow...
Old Sep 3, 2008 | 09:05 PM
phee's Avatar
I got the Shifts
you must have not been using ss? (Sportsshift)
Old Sep 3, 2008 | 09:53 PM
thinhthan's Avatar
is that wen i put it to the left after d4? i thought that was bad for the car?
Old Sep 3, 2008 | 09:54 PM
thinhthan's Avatar
wen should i shift up in the ss?
Old Sep 3, 2008 | 10:30 PM
02type-s's Avatar
-Arsenic-
Using SS or not, that time is way high
Old Sep 3, 2008 | 10:31 PM
Razzi's Avatar
T-Swzy
there is a bit of delay when you hit up and when the car shifts, i do mine about 500 rpm before redline and it throws up the gear right on cue. every car is different a little bit, take yours out to an on ramp a few times and see what works for you.
but as far as shifting SS and letting it full auto, if you pedal to the metal auto will still shift at redline wouldnt it?
Old Sep 3, 2008 | 11:08 PM
thinhthan's Avatar
yes thats why i just left it on the auto. i didnt think there is a different. i don know why my car is so slow. can any one show me how to launch my car ?
Old Sep 3, 2008 | 11:12 PM
phee's Avatar
I got the Shifts
using ss will not damage the car anymore than using it in full auto will. all your doing is sending an electric signal to the transmission to tell it when to shift up, same thing your ECU does
Old Sep 4, 2008 | 12:25 AM
thinhthan's Avatar
would my car run faster if i race with the ss? and is there a way i should launch the car?
Old Sep 4, 2008 | 04:42 AM
Rajca's Avatar
when i leave my car in auto it shifts at redline (7k rpm) i shift at about 6500-6700rpm right where my max power its.
Old Sep 4, 2008 | 11:26 AM
thinhthan's Avatar
how do i launch off start?
Old Sep 4, 2008 | 11:50 AM
Rajca's Avatar
hold the brake, give it gas to about 1800, let go of brake once the u see the green light, and if the tires spin next time drip the rpm by 200 or if they dont spin raise it up by 100 or so.
Old Sep 4, 2008 | 12:45 PM
fsttyms1's Avatar
Gate shift. Put it all the way down to 1 and do what Rajca said above. when at redline shift to 2nd etc....
I ran a 14.9xx as my best time in my 2000 TL, i averaged 15.2 (just intake and mufflers)
Old Sep 4, 2008 | 02:43 PM
thinhthan's Avatar
will it be the same if i just put it in d5?
Old Sep 4, 2008 | 02:55 PM
6MTUA5's Avatar
No He Can't
Have you been since the swap?
Old Sep 4, 2008 | 03:58 PM
Edward'TLS's Avatar
6G TLX-S
Thinhthan, you mentioned that something wasn't working properly with your tranny, inside the "problems & fixes" sub-forum.
I suggest that you DON'T try to race your car until the tranny is fixed. If it is really the 3rd gear clutch pack starting to come apart inside your tranny, the broken pieces will clot up the transmission oil filter, and you may experience a dangerous sudden lockup with your car at highway speed (worse still, during a high speed corner) when the tranny suddenly shifts from 5th gear to 2nd gear.
Old Sep 5, 2008 | 12:53 AM
thinhthan's Avatar
well i only got thats problem with the reverse and only if i dont push the e brake than put it in nutral than let the brake off and let the car move a lil than put it in park. it doest have any problems down shifting or anything like that
Old Sep 5, 2008 | 01:00 AM
Edward'TLS's Avatar
6G TLX-S
Last time when my tranny crapped out, I also had problem with the reverse. The problem then kept getting worse until I finally lost 3rd gear completely.
Old Sep 5, 2008 | 01:10 AM
thinhthan's Avatar
i see thanks for the advice. but when i do what i do wen i put it in reverse it goes in fine?
Old Sep 5, 2008 | 10:06 AM
ArTL-S's Avatar
I have dead hookers in
I think his point is that you shouldnt have to do anything to get it to work fine besides put it in reverse. If you are having to do a little trick to get it to do right then something is already wrong man. BE careful with it. On a strip if you have a wreck at those speeds you can hurt yourself and others that are just there to watch very easily.
Old Sep 5, 2008 | 10:08 AM
fsttyms1's Avatar
no.
Old Sep 5, 2008 | 10:10 AM
fsttyms1's Avatar
13.98x (once) Launching it is half the battle. I think better more consistant times can be had with a 2nd gear launch. Especially once i get the 3.5 and SC
Old Sep 5, 2008 | 10:42 AM
phee's Avatar
I got the Shifts
wow, a full second. maybe you can hit high 12's if you have slicks?
Old Sep 6, 2008 | 03:32 PM
ChrisQ1980's Avatar
hates the winter
X2, gate shifting is best for 1/4 use in the TL. The hardest part is to launch it without bogging, or too much tirespin. SS is more for winding roads, on/off ramps.
Old Sep 6, 2008 | 03:39 PM
ChrisQ1980's Avatar
hates the winter
Here is a very short vid of my gateshift from 1-2. I had to stop because a car pulled out up ahead and I didn't want to have to slam on my brakes.
http://www.youtube.com/watch?v=qsAG1v4Kz_M
MrHeeltoe
20
Feb 23, 2023 01:54 PM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
