Tune upon
Old Nov 12, 2010 | 02:30 PM
taintedplay's Avatar
Tune upon
I'm taking my car into the mechanic because my ac/heater isn't blowing air, and wanted to get a tune up. My car has been really sluggish lately. Any ideas on how much it costs?
Old Nov 13, 2010 | 02:16 AM
01tl4tl's Avatar
how many miles???
replace the sparkplugs with NGK Iridium, 50 bucks in parts,,8$ each x6
labor 1 -1.5 hours
DIY-run seafoam cleaner thru half tank of gas $8 can x 2 times
replace engine air filter $25
if your ac blower stopped totally -it may have burnt the connector wire and fried the resistor--pretty easy diy,,same as change cabin air filter and add a few more screws to remove 30-60 minutes DIY
Acura sells a replacement kit with longer wires and new connector- $20
look on back of mount plate for blower motor to ck resistor for damage- dont have price
using fan on 5 all the time contributes to prob of short wires and cheap connector
Heat does them in--fan on high is lots of amps= heat in wire
Old Nov 13, 2010 | 02:40 PM
VQPower37's Avatar
is this true for the 3g as well in terms of frying wires by using the fan speed on five always??
Old Nov 13, 2010 | 03:51 PM
no, he's saying it could contribute to the death of the wires.
too much electricity all the time can melt something.
Old Nov 13, 2010 | 07:07 PM
01tl4tl's Avatar
the connection is very tight due to short wires--that adds to the problem.
the update kit has longer wires
honda used a similar connector on their motorcycles and same type heat damage occured with melting of connector- wires damaged and come loose..arcing occurs--FIRE!! -under the seat!!
(happened to me-main power leads on bike!)
Old Nov 13, 2010 | 08:53 PM
totaledTL's Avatar
Why not read up on the blower repair & do it yourself (or try before you take it to somebody else) to save some $?
Old Nov 13, 2010 | 10:14 PM
MurkyRiversTL's Avatar
COTM Coordinator
Check ebay for NGK iridium plugs. They go for 34 for all 6. Better than 50
Old Nov 13, 2010 | 11:43 PM
01tl4tl's Avatar
make sure you get the correct ones
type S cars have a step colder heat range
I dont have the part numbers and hear there are a few choices on the order site for ngk
went to local store for mine, for ten bucks differance than online- that store is there... available to buy my engine oil from-- and return the used oil to!
the gas money to the hazmat oil disposal a few times just about covers the differance in plug price
ngk Iridium, iridium IX (somehow racier and used by many), laser iridium (refers to how the electrode is welded on- a laser did it) or even Platinum all ok (plats are whats in it stock but now cost more than the better/improved iridium)
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
