Is that True???
Originally Posted by bitemeeh
It can be that or your axle boots are riped or your pads were mounted inproperly on the brake caliper. I have seen defective brembo rotors be4, New rotors does not mean its not defective.
Originally Posted by NYCdesiPola
thanks a lot bro...l will check my brakes this weekend & exchange the rotors but axel l can't see any oil outside but actually how do you check the axel?
If you look at the axle boots, they should be intact, if they are greasy and are ripped, you will need to replace them asap, other wise it will eventually worn out your bearings.
It's pretty easy to inspect the axle boots. Like bitemeeh said, take a look at the rubber boots, and make sure they are not torn or anything. If you see grease all over the area, then it probably is torn and spitting out the grease everywhere.
Originally Posted by 99bluetlwtt
I recommend the Brembo Blanks or Rotara with either Axxis Ultimate or Endless pads. Personally I have the Brembo Rotors and Axxis Ultimate pads. I have to say they are the best.
like l said there is no greasy or any sign of ripped so how l'm gonna find out the inside of it? maybe something wrong inside?
I can vouch for Cross/dimpled drilled from Irotors.com too! I had driven more than 65k miles and they are still running fine. If you are sick of warped rotors, go with aftermarket rotors and pads for sure. Here are some pics of my irotors.
mlody
Dec 4, 2019 02:11 PM
SiClone
Oct 1, 2015 10:22 PM
