car is running sluggish
Old Mar 21, 2006 | 07:07 PM
FREAK2215's Avatar
ive been noticing that my first gear is kinda sluggish and the car at normal gears doesnt pick up as much until vtec ....any advice, im gonna do injector cleaner on my next tank but anything else i could look at ?
Old Mar 21, 2006 | 07:51 PM
RickRoush03's Avatar
RickRoush03
that your car is not having a misfire? how many miles you got? air filter clogged or dirty, maybe something got stuck in the intake like a plastic bag?
Old Mar 21, 2006 | 07:59 PM
snowman81's Avatar
Sippy Cup (x2)
or maybe the O2 sensor...not sure
Old Mar 21, 2006 | 10:17 PM
FREAK2215's Avatar
i recently put a cold air intake but even before that it was the same, 2000 72000 miles but brand on transmission #3 prolly not even a year old
Old Mar 21, 2006 | 10:18 PM
FREAK2215's Avatar
i recently put a cold air intake but even before that it was the same, 2000 72000 miles but brand new on transmission #3 prolly not even a year old
Old Mar 22, 2006 | 08:51 AM
NSXNEXT's Avatar
Is the check engine light on?
Old Mar 22, 2006 | 08:54 AM
NSXNEXT's Avatar
Did you check fluid levels,especially oil?
Old Mar 22, 2006 | 09:30 AM
varunverma23's Avatar
doesn't a faulty O2 sensor trigger a check engine light? My car seems to be running sluggish as well. It used to pickup way faster when i first got it. I've already checked all the fluids, used fuel injector, checked air filter, changed plugs and it hardly keeps up with my friend's 99TL.
Old Mar 22, 2006 | 09:53 AM
NSXNEXT's Avatar
It absolutely should.
Old Mar 22, 2006 | 09:59 AM
fsttyms1's Avatar
with NSXNEXT. If its faulty it should be throwing a code
Old Mar 22, 2006 | 10:15 AM
MarbleGT's Avatar
'08 MX5 GT 6spd.
my o2 sensor went out yesterday, VSA/check engine lights came on, car shifted harder than normal, ran very sluggish. I thought it was the tranny again. The multiple tests relealed it was the o2 sensor
Old Mar 22, 2006 | 11:54 AM
so what else could cause it to be sluggish?
Old Mar 22, 2006 | 12:14 PM
Pure Adrenaline's Avatar
Dragging knees in
Anything and everything.
Insufficient air intake, clogged injectors, a problem causing a timing retard, bad fuel, high humidity weather, etc, etc, etc.. and most importantly, your own perception of the speed.
Sometimes you think it's gotten slow, but in truth, it's still the same. It just feels slower to you because you're used to it. I go through this like everyday. That's why I kept on modding.
Rest assured, if there was a problem with the car, the check engine light would most likely tell you that there is a problem.
Old Mar 22, 2006 | 01:17 PM
miamirice's Avatar
Yup
My TL feels horribly slow as well, and not just in 1st gear. I'm not sure what is wrong. It is so bad that I wonder if all 6 cylinders are working.
Old Mar 22, 2006 | 02:27 PM
NSXNEXT's Avatar
To reiterate what Pure Adrenaline said, with today's modern cars, even the slightest hiccup will cause a CEL. If the lights not on, it's probably your imagination.
Jeez, not tightening the gas cap will throw a CEL.
Old Mar 22, 2006 | 03:15 PM
2K2SilverTL-S's Avatar
AZ O.G NoOldManVetteOwner
Take all the coils out and test them. One of mine was misfiring intermitently without throwing a code.
Old Mar 22, 2006 | 04:28 PM
How do you test each coil? Just put one in at a time and start the car?
Old Mar 22, 2006 | 07:58 PM
NSXNEXT's Avatar
No, you need to go and buy (or borrow) a good one and swap it out with each one, driving the car for a bit to see if it makes any improvement.
Old Mar 22, 2006 | 08:30 PM
fsttyms1's Avatar
Oh you would know if you wernt on all 6!
Old Mar 23, 2006 | 07:54 AM
miamirice's Avatar
Yup
How?
I mean, I'm half joking about my TL, but my first car, a used '88 Nissan Pulsar NX, took me around for YEARS - with quite high RPMs but just incredible gas mileage - and it was after I had passed it on to my brother that one of his mechanics told him one out of the four cylinders wasn't working.
Old Mar 23, 2006 | 11:09 AM
My freind's car was misfiring. U could tell. It wasnt smooth at all, and the check engine/ tcs light was on. Very rough idle as well.
Feb 25, 2020 09:57 AM
Fabian43
Jul 13, 2016 09:07 PM
Phambam12
Sep 6, 2015 06:57 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
