Transmission Pig Tails - Where to get them??
Hey guys.
I have a 03 TL with 185k on it. I just had the trans rebuilt. I am a pickup truck guy and this is the first FWD trans I pulled. When I pulled it for my trans guy, I missed the 2 pig tails on the top shifting servos. They hide under the intake near the starter. I have googled the best I could and have called the 2 local dealers to me and struck out. I know Honda/Acura has to sell pig tails. At least I hope so. GM and Ford do. Does anyone know where I can find the part number or have a dealer with a good parts guy?
I tried to take apart the plugs, but failed...
Since this car is down, I am DDing my dually and that is starting to hurt money wise. My new trans is in. Just need these 2 pigtails.
Here are the two pig tails I need.
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/IMG_0237_zps7baf87f2.jpg)
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/IMG_0236_zps6e4ba3bc.jpg)
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/IMG_0235_zps98087fd8.jpg)
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/IMG_0238_zpsb2927a81.jpg)
Any help will be great!
036speed (12-16-2013)
Mr.Helpful Diagram
If your good with a soldering gun you can repair them, the inside where the pins go through thats a cover thats clipped on, once off it exposes the tabs that hold them in place. I do have spare ones here I'll have to find them.
Thanks man! This was a big help. I am going to order the plugs from there. My buddy at Honda hooked me up with the wire colors.
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/12-16-20139-53-02AM_zps6541ea7d.jpg)
My trans went. So I pulled it and sent it out to get rebuilt. When I pulled the trans, I realized that I missed two connectors. That is when I took the pics.
That was plan A. However, I was not careful enough and broke the plugs when I was disassembling them. On the bright side, I know how they work now...
So now the plan is to get new plugs, or find used ones and go from there. I will have to visit the local JY this week sometime.
Mr.Helpful Diagram
You should really consider the 06-07 accord tranny instead of rebuilding the one you have, Its the proven alternative for these cars.
I just want to get another 80k / 2 yrs out of my car. So this should work out.
Mr.Helpful Diagram
Ok yea I went the same route and then I found out the success stories, mines 2 years now and still ok just drain and fill yearly.
I hear thats they key. The last one is in this car was drained and filled every 30k. Then after 100k, I started doing it every 15k after reading some things on here. Got 160k out of it. The trans guy was impressed lol.
Mr.Helpful Diagram
Yea some are lucky.That is good but there's a member here that went 250k irrc I believe doing the same thing since new.
That's a huge tranny you got there is that from the Ford Pick up?
That is a 5 speed trans (FM-146) out of a late 80s, early 90s Ford Ranger. Long suckers. But very few sensors lol
Mr.Helpful Diagram
That's the guy ! 03Blackbeast did you ever get to clean the solenoids?
Haven't had time yet and it's freezing cold out. Wouldn't be much fun in my apartment parking lot but I'll have to get around to doing it. I'm still trying to find a diagram/picture/DIY thread to show where they're all located. Doesn't sound too hard just haven't found a way to see how to do it.
Thats awesome!
Well, the local JY got this beast in on Monday. So I went and got the pigtails I need.
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/9EB63CFE-4B59-4758-84E8-25BF8A35FB5B_zpsmkxypmwm.jpg)
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/F1CDDEEB-1009-477E-BEA6-34D2CA49EBDD_zpsftl47nhh.jpg)
The trans is in and works well. I did some testing last night. Drove about 10 miles. Everything was great.
Drove it to work today. The CEL came on and its spitting coolant out the exhaust. The car is getting hot and I have no heat in the cabin. The only coolant line I unhooked was for the ATF heater.
So I had my wife rescue me again. I swear this thing has some kind of virus or something. Its been a perfect car up til now. Guess I know what I am doing this weekend.
There are coolant and vacuum lines under the throttle body Its easy to not know its a coolant line thinking its a vacuum line. . Its very easy to get them mixed up. Recheck the lines under that area and make sure they are hooked up correct.
Thats my plan. I didn't unhook too much. But you never know. I could be sending my coolant into the intake... The oil still looked good.
This thread topic has now changed.
Went to tow my car home last night. Now it wont fire. Turns over but doesn't even try to fire. The engine oil is also now milky.
All the lines look fine. I compared them to the pictures I took before I pulled the car apart.
I got 8 codes.
#1: P0301 Cyl #1 misfire
#2: P0302 Cyl #2 misfire
#3: P0303 Cyl #3 misfire
#7: P0300 Multiple misfires
#8: P1399 Misfire in any cylinder.
I hoped the scanner would tell me more than what I already knew lol.
So now we have tonight's project.
I got 8 codes.
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/79B6DB6C-BDC2-4BDC-8B8F-82C86FDC771E_zps6vctbgcj.jpg)
Mr.Helpful Diagram
The only thing I can think of without blaming the head gasket is the IACV it also has a rubber gasket, check if its damaged. Its under the throttle body and has coolant lines going to it.
036speed (12-20-2013)
HGs are not common on these cars are they? I has to be something I bumped.
Yeah, recheck the lines as these guys said.
If ya have not already drained the oil and coolant, ya may want to get that stuff out and try to flush the residuals for a fresh start.
Clear the codes by removing the "clock" fuse for a few minutes. It's located in the passenger side lower kick panel.
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/PhotoDec22121019PM_zps059484a5.jpg)
![](http://i123.photobucket.com/albums/o307/muddinford95/TL/PhotoDec22121024PM_zps75e54b5b.jpg)
Mr.Helpful Diagram
There's a possibility that coolant is creeping thru that pcv tube since it has a coolant line with it, Disconnect it from the valve cover and coolant hoses then check it for leaks.
You can also check it with the engine running but you will need to refill the coolant and change the oil since its contaminated.
