transmission
Yeah, that's about normal.
I've had two trannys go on me. But I believe they have finally fixed this problem. Considering, that I've put about 35K to 40K on tranny number three with no worries.
Tranny 1 and 2 went pretty suddenly, there was only like 4 days of symptoms before they failed completely.
from park or like reverse to D5? if so yea thats normal
TL-S driver
before my tranny change, shifting was definitely delayed, but it seems that after I got my new tranny, the shifts are quicker. Is that right or am i just imagining that?
Yeah, they reduced the clutch disengage/engage time to reduce clutch grind. I believe they also increased oil flow around tranny and reduced friction coefficient of clutch plates...
funny... if you redline the engine and switch gears... you might hear a "chirp", that chirp might be the clutches as opposed to the tires... I think.
I also notice the delay but percieve TWO engagements about 1 second apart.
Especially when switching from reverse to D5. I have come to be cautious
when backing out of a parking spot because if I hit the gas as I feel the first
nudge of an engament the second one will kick in too sharply. It just doesn't
"feel" good on the tranny. Perhaps all I am doing is forstalling the inevitable
transmissioin failire,...who knows.
I HATE the way this transmission behaves. Especially when cold. Very sharp
engagements until warm and then it smooths out considerably. I believe many of
the dealers knew about this quirkiness since every time I went on a test drive
and when picking up the car they made darned sure that the car was hot. After
I purchased the thing and noticed this behavior the service manager said it would
smoothout after a break in period.....Bullshit.
joflewbyu2
10-08-2015 11:16 AM
