Trans Questions
PROSTREET440
Trans Questions
I JUST BOUGHT A 02 TL TYPE S AND HAVE BEEN READING ABOUT ALL THE PROBLEMS WITH THE TRANYS ON SOME CARS
DOES ANYBODY KNOW IF USING THE AUTOSTICK VS. NOT USING IT HELPS WITH TRANS LIFE? CAR SEEMS FINE AND I LOVE IT SO FAR (REPLACED MY 91 LEGEND LS COUPE WITH 250K ) DOES ANYBODY RECOMEMD A TRANS FLUID OR FIX THAT HELPS TO KEEP THESE FROM A MELT DOWN ?
Let me be the first to welcome you..and secondly, please type with the "Caps Lock" off. When typing in all caps..it's pretty annoying..and seems like you are yelling.
Secondly, this topic has already been beaten to death..search next time.![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
http://www.acura-tl.com/forums/showt...ranny+problems
doesnt matter how you drive it or if you use auto stick or not, if you have the defectif part its gonna go
http://www.acura-tl.com/forums/show...tranny+problems
thanks brian for beating me
Edit* You can check to see if your VIN# falls within' the defective trannies here.
Forgot to add that a tranny cooler might help the tranny problem..but don't expect it to make a bad tranny into a good tranny.
Here's a link to a B&M Tranny Cooler http://www.jcwhitney.com/webapp/wcs/...-1&PID=1412752
My 2002 TL-S is now on Tranny #5 and I almost never use the "Autostick" mode. This last unit has lasted 11 months so far and I am feeling good that it will make it until August which is the end of my lease.
If your 02 is still on it's original trans then it is a good bet that you have a good one. Some of the replacement units I received only lasted 1 month.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
