Tranny Issue or IACV?
Old Mar 22, 2010 | 12:36 PM
Chip's1999TL's Avatar
This is the problem that I'm having. My car is as smooth as butter in park, reverse and neutral. When I put the car in D4 or SS it idles rough, not as rough as it was before I did the tings below. Could it be the IACV or is a tranny problem. The tranny was replaced last August and the car never did that before they replaced the tranny. Any suggestion or ideas on what the problem could be?
This past weekend I just cleaned my EGR port, that thing was totally clogged with carbon. Changed spark plugs (NGK IX) and changed the PCV valve.
Also I don't have a problem with the RPM's jumping all over the place like I've read that some have with IACV problems.
Old Mar 23, 2010 | 01:00 AM
01tl4tl's Avatar
recheck spark plug torque - none loose- and all vac lines connection
IACV is usually a 1000 rpm jump from 1000-2000
ck front and rear motor mounts for vac booster, lines and condition of mounts- look for fluid leakage from it
ck vac lines from egr port job all got hooked up right- sometimes a vac hose end tears and wont seal tight - replace vac hoses as needed
did it do this only since you worked on it??- or since trans was replaced- which could be a tq problem or something
egr cleaning- you removed the manifold and TB- did you clean the IACV when it was all off the car?
Old Mar 23, 2010 | 01:02 AM
01tl4tl's Avatar
I have heard of accidentally switching the coolant and vac lines near tb- wont run right sucking coolant in the engine
Old Mar 23, 2010 | 09:32 AM
Everything is connected right. I noticed this problem right after I got my car back when the dealer replaced the tranny. I took it back a few days later and they noticed it and said they didn't know what was wrong with it. But now that I think about it, it was something that they did, it wasn't like that before I took (had it towed) it to the dealer for a tranny repair.
Old Mar 23, 2010 | 09:33 AM
Also, I didn't take the TB off when I took off the IM to clean the EGR port.
Old Mar 24, 2010 | 02:49 AM
01tl4tl's Avatar
so you shook the manifold all around getting the rinse water out- with the TB attached?
how did you clean and rinse the manifold at all like that?
I always suspect the most recent work done but if you had a problem right after trans install you need to go back to the dealer
after rechecking all the last work you did- How exactly did you clean the egr port?
Old Mar 24, 2010 | 08:18 AM
Sorry I guess I wasn't clear. I took only the IM off and left the TB attached to the the air intake (black hose). I followed the steps from the Acura Service Bulletin for installing that EGR pipe kit without taking off the TB.
Sprayed carb cleaner (2 cans) throughout the IM and rinsed thoroughly and then reconnected everything in the right place. I'll check again to be sure.
I will be making a trip to the dealer this weekend.
Old Mar 24, 2010 | 10:54 AM
01tl4tl's Avatar
Im not getting the visual of how you did this without moving the TB in a funny way, or being able to clean the IM completely
was the recall installed kit there for the egr port?
Old Mar 26, 2010 | 01:24 PM
No the recall kit was not installed for the EGR port and I did not clean the TB, just on the side where it went into the IM.
Old Mar 26, 2010 | 02:16 PM
fsttyms1's Avatar
When you put the top IM cover on did you place the gasket on correctly, it fits 2 ways, 1 way is wrong and will cause shaking.
Old Mar 26, 2010 | 02:27 PM
01tl4tl's Avatar
it goes on upside down and looks right but blocks a port iirc
Old Mar 29, 2010 | 07:03 AM
I didn't take the gasket off.
Old Mar 29, 2010 | 11:15 AM
01tl4tl's Avatar
we are talking about the gasket between the top cover and the intake= you didnt remove that to get the manifold off? the gasket was intact or what?
as I always say- suspect the last work done
at least take the TB off and clean the IACV
Yikes
May 3, 2021 04:29 PM
cycdaniel
Dec 17, 2019 10:58 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
mugen_kid
Nov 13, 2015 10:38 PM
kuzdu
Sep 10, 2015 08:42 PM
