Tranny Fluid...
While your at it, you should do the seafoam treatment. Get the can "Deep Creep" for the vac port. It's much easier and less messy then doing it from the can. Get the can and dump it in half a tank of gas and run it close to empty, then fill up with half a tank again and do the same. It will increase your mileage significantly, and clean out the entire fuel system and combustion chambers. Pep boys has it.
Originally Posted by ChrisQ1980
Go to the honda dealer, it's a lil cheaper than the Acura dealership. Honda ATF Z1 fluid ONLY. You will need 3 quarts to do a fluid change, 9 if you do the 3x3 drain/refill.
yeap honda cheaper by far. just bought mine today 6.69$ a quart from honda and 7.35$ from the Acura dealership not to mention the gas in millage difference because Acura is a distance for me.
Pham Alvan
May 18, 2021 06:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
lanechanger
Oct 13, 2015 10:56 AM
