TL engine replacement, Need Help
Old Jan 1, 2008 | 12:17 AM
bsd083's Avatar
9th Gear
Exclamation TL engine replacement, Need Help
Hi, in replacing the motor in my girlfriends 00 tl, now i have done engine replacements on hondas and similar, but never the 3.2 and this is really important that it is done at the end of the week . (she has school) but what should i know that is going to bite me? and tips ideas ect would help. also the service manual i (alldata) says to remove it on a hoist from the bottom side? i looked i think it will clear out the top side, and odvisously i dont have a hoist, so has anyone done this on stands? is it possible? Thanks to all you wonderful acura owners out there.
Old Jan 1, 2008 | 02:06 AM
01tl4tl's Avatar
check the DIY section for thread by fsttyms1 on motor swap- its about putting in a different motor but all the removal stuff is there i think
Old Jan 1, 2008 | 08:50 AM
Rajca's Avatar
wham bam thank you ma'am
its going to be extremely hard to do it without the engine hoist. me my bro and his friend (acura master tech) took out an engine and trans from one car and put it into my other tl-p. process took about 3-4 hours and it was running. the putting everything back together sucked.
Old Jan 1, 2008 | 09:16 AM
fsttyms1's Avatar
rent a hoist. Keep the trans attached. (it will be far easier to mate the 2 together outside the car, for a novice thats never done it before) Unplug the engine harness from the ecu and fish it thru the firewall. It will be easier to reattach every thing outside the car. Pull it out thru the top. It will be easier if you just remove the 4 screws that hold the hood on.
Old Jan 1, 2008 | 09:41 AM
bsd083's Avatar
9th Gear
oh, sorry, i have an engine hoist (crane) to pull it out from the top. But the directions say raise the vehicle on a hoist lift and lower the engine out the bottom of the car with a chain lift. ?? does the factory service manual say this too or is it just my alldata? thanks again.
Old Jan 1, 2008 | 11:04 AM
fsttyms1's Avatar
Just all data. Ive pulled the engine and can say it comes out the top very, very easy
Old Jan 1, 2008 | 11:11 AM
bsd083's Avatar
9th Gear
also i assume if i pull it out the top i dont need to remove the subframe right?
Old Jan 1, 2008 | 05:44 PM
fsttyms1's Avatar
No that can stay put
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
wusty23jd
Sep 24, 2015 11:41 AM
iCrap
Sep 11, 2015 06:21 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
