Timing belt tensioner issues
Old Mar 2, 2019 | 03:30 PM
Chris Kaz's Avatar
Hi I have a 2002 Acura TL type s and have been having an issue with the timing belt tensioner, it failed when I got the car and I then replaced it and it failed again within 2 weeks, trying to find out if the idler wheel could be bad causin it to fail or the other tensioner, was hoping to get other people’s opinions before I go throwing money at it
Old Mar 2, 2019 | 04:19 PM
horseshoez's Avatar
Latent car nut
The timing belt tensioner failed, twice, and you didn't bend any valves? Sounds odd.
Old Mar 2, 2019 | 09:59 PM
Chris Kaz's Avatar
i did a compression test to see if anything was wrong and it was 200 across the board
Old Mar 2, 2019 | 10:03 PM
Chris Kaz's Avatar
Why is there normally something wrong with the valves if the tensioner goes?
Old Mar 2, 2019 | 10:17 PM
horseshoez's Avatar
Latent car nut
Yes, if the tensioner goes then the belt will jump teeth and you will bend valves.
Old Mar 2, 2019 | 10:45 PM
Chris Kaz's Avatar
well basically the tensioner does not completely fail it just starts making a horrible noise around 1k to 2k rpm and when I pulled the front cover off it was coming from belt vibration so I changed the tensioner and it stopped that belt vibration for a couple weeks and now it is back, I assumed it was the tensioner failing
Old Mar 2, 2019 | 10:50 PM
Chris Kaz's Avatar
I ordered another belt tensioner so I am going to install it and see if it will last longer and hopefully it completely stops the noise
el.profe
Feb 20, 2020 06:26 PM
kaushiknair
May 15, 2013 02:44 PM
NSXNEXT
Sep 8, 2008 08:42 AM
CLpower
Nov 19, 2004 02:56 PM
allmotor_2000
Sep 28, 2003 02:18 PM
