Timing belt question
Old Aug 12, 2008 | 12:27 AM
tlzib's Avatar
Im sure this has been beaten to death but had a quick question. Now im a past due on replacing my timing and other parts to get her back in shape. Im know to use only honda/acura parts. Now i was looking on ebay and saw the kits i know dealerships dont sell kits but this seems legitimate. Can anyone let me know if this is all i need and or if i should not waste my time. I apologize advance for my post but i just gotta double check with you pros, any help will be much appreciated.
Old Aug 12, 2008 | 02:38 PM
tlzib's Avatar
Anyone hear is the link
http://cgi.ebay.com/ebaymotors/Acura...spagenameZWDVW
Old Aug 14, 2008 | 02:57 PM
swalch@stanford.edu's Avatar
That kit is really cheap. If it's original equipment parts it's a good buy. There is also an idler pulley that I would replace at the same time.
Old Aug 14, 2008 | 03:47 PM
ChrisQ1980's Avatar
hates the winter
WOW, $139 free shipping??????? He says, they are OEM honda parts OR they are made by the same companies that Honda uses. Maybe he gets them as honda does, but without the Honda packaging and part numbers.
Old Aug 14, 2008 | 09:05 PM
patrick's Avatar
IMHO, I would get the OEM Acura timing belt. If the aftermarket replacement belt breaks due to poor quality, you will be looking at one expensive repair bill! Not worth the hassle.
Old Aug 15, 2008 | 10:32 AM
I got the parts for the timing belt job on my daughter's 2002 TLS from auto parts warehouse. They had the Honda packaging and looked to be genuine Honda parts at quite a bit below the dealer price.
Old Aug 15, 2008 | 10:58 AM
totaledTL's Avatar
Did they advertise that they were OEM parts, or you didn't know until you rec'd them?
Old Aug 15, 2008 | 05:38 PM
tlzib's Avatar
Thank you all for the responds. I just wanna make sure thats all i need is in that kit, or is there anything else i should pick. I already did plugs and few a other things.
Old Aug 16, 2008 | 03:49 PM
They were advertized as OEM.
Old Aug 16, 2008 | 06:03 PM
jimmiexiong's Avatar
idler pulley? is that the timing belt tensioner or something else? im looking to replace my timing neltz too, just need to know what else to replace since im doing it!
thnkz
jimmiexiong
Old Aug 17, 2008 | 09:35 AM
The idler pulley is separate. There is a timing belt tensioner which pivots and has an idler pulley as part of it. There is another separate idler pulley on the other side of the belt. In addition to these there is the water pump, the belt, and a spring loaded tensioner. You can probably reuse the spring loaded tensioner if you have access to a strong vise to re load it, or the shop manual suggests a procedure to hold it compressed using one of the battery mount bolts.
Old Sep 10, 2008 | 10:24 PM
Superdesi's Avatar
I have in the past purchased many Honda parts on eBay from the seller " NV Thai " that were priced cheap and shipped fast.
vaughanml2
Nov 1, 2021 10:16 AM
redsox68
Sep 16, 2015 06:18 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
