Timing belt help
Old Mar 20, 2013 | 04:37 PM
eyesnake02's Avatar
Timing belt help
So i lined up both cam gears to the mark, but my crank gear is not lined up what should I do? take the belt off and line up the crank mark?will it ruin anything.I haven't taken the belt off yet.
Old Mar 20, 2013 | 05:26 PM
victus1's Avatar
Are you sure it's not lined up? It's hard to tell from the orientation/alignment of that photo.
I thought mine wasn't lined up too....but it was actually an optical effect of lining up my eye properly. After turning the engine a few turns, I used a straight edge to confirm that all 3 marks were lined up and they were all spot on. Although the crank mark didn't appear like it was to my eye.
After turning the engine a few times and checking with a straight edge and its not lined up....take out the belt. You will need to compress the tensioner on a vice very slowly for about 2 minutes to bottom it, then put the pin on it and try again.
Old Mar 20, 2013 | 05:40 PM
assclown's Avatar
2000 acura tl FPR
Here's a quick video of it, I'm going to use zip ties next time I change my timing belt.
Old Mar 20, 2013 | 05:53 PM
eyesnake02's Avatar
The thing is i haven't replace the belt yet. my car was running like that originally.if I remove the belt and set the crank to the mark and put belt back on will it ruin anything?
Old Mar 20, 2013 | 06:04 PM
eyesnake02's Avatar
this might be better
Old Mar 20, 2013 | 06:23 PM
fsttyms1's Avatar
No it wont ruing anything. It will probably run better. It is one tooth off. Are you sure your cam gears are aligned?
Old Mar 20, 2013 | 06:51 PM
eyesnake02's Avatar
pretty sure. even when i line up my cam marks the dot on the crank pully and timing cover was kinda off.
Old Mar 20, 2013 | 08:16 PM
victus1's Avatar
Well.....ask yourself this: do you need timing belt service....is it due soon? If so, do it now and change out all the 5 components for the tbelt service. Otherwise, 1 tooth off is not going to kill ya. It may just waste a bit more gas, if anything....hardly noticeable.
Old Mar 21, 2013 | 06:53 AM
fsttyms1's Avatar
No, that isnt lined up either. Look at the little mark by the teeth of the timing belt. It is one tooth off as well, your belt is where its supposed to be. Line up your crank and the line will line up too.
Old Mar 21, 2013 | 06:56 AM
fsttyms1's Avatar
vaughanml2
Nov 1, 2021 10:16 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
