Ticking sound while accelerating
Old Oct 19, 2014 | 06:52 PM
xDev007's Avatar
6th Gear
Hey guys! I have a 2003 TL Type-S with 80k miles on it and have just recently developed a small problem with it. I changed the sparkplugs today (NGK Iridiums) and when I fired up my engine and took it for a spin, I noticed a faint ticking sound when accelerating. It's pretty annoying to constantly hear whenever I accelerate, and it's loud enough to be heard while driving the car. Even if I tap lightly on the gas pedal in park it still makes that sound. Is it possible it's somehow related to the sparkplugs? I think it would be too a big a coincidence otherwise as it only appeared directly after changing them. My dad knows about cars and he thinks it might be related to the fuel injector, but I want to know what you guys think.
Thank you!
Old Oct 19, 2014 | 07:03 PM
Skirmich's Avatar
There are 2 possible things that might "Tick" when on the Gas will follow RPM and when on IDLE they still Tick:
EGR Solenoid and Valves.
EGR Solenoid: is located on top of the Brake Master Cyl and its pretty annoying when it ticks.
Valves: Pretty unlikely they started to tick with your spark plugs change.
Old Oct 19, 2014 | 07:43 PM
MarcDavidoff's Avatar
My first thought would be since you just changed the plugs and it appeared directly afterwards, I would recheck all the plugs to make sure they are all tight. You may possibly have one loose
Old Oct 20, 2014 | 07:08 AM
3.2TLc's Avatar
^^^ Yeah, if the ticking wasn't apparent before replacing the plugs.....recheck your work and anything that may have been disturbed in the process. Try to isolate the source if possible. The "EVAP" solenoid near the driver's side firewall is known to cause a ticking sound.
Old Oct 24, 2014 | 08:26 PM
01tl4tl's Avatar
a loose spark plug will allow gas to escape the combustion chamber and cause a ticking like sound
did you torque them or just tighten by guess?
Old Oct 24, 2014 | 08:28 PM
01tl4tl's Avatar
you all know my rule: If a new problem occurs after work performed- recheck that work!
we have seen recent examples here of did one project- managed to blow a fuse for something seemingly unrelated and no start or whatever- you get the idea
Old Dec 12, 2014 | 02:00 AM
xDev007's Avatar
6th Gear
Hey guys, thank you for all the replies. I haven't visited the forums in a while and completely forgot about this post. I guess that might be a good thing as the problem went away on its own
You guys are awesome by the way. So many responses from the community to help resolve a problem I have. This is why I love owning an Acura, they have the best userbase in their forums.
Old Dec 12, 2014 | 03:04 PM
3.2TLc's Avatar
^^^ Sometimes ya get lucky !!!
Be sure to check out the many common problems and fixes within the 2nd Gen's "DIY" sticky.
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Aug 18, 2019 10:38 PM
DerrickW
Nov 15, 2015 05:52 PM
prbori
Sep 27, 2015 01:37 AM
TL14
Sep 24, 2015 04:37 PM
