Ticking Noise after changing spark plugs
So I changed my spark plugs out on Sunday. Monday, I drive home and I hear this low ticking noise when i barely gas it. Sounds like I need a valve adjustment in a way. Could there been anything that I did wrong when I installed the plugs to cause a noise like this? The car runs fine, just the ticking noise. Thanks
Open hood after dark and make sure you dont see any arcing. Look closely at all the plug wires/boots. It is possible to push the boots on to far and cut through the outer layer which results in the electrical charge escaping the wire causing an arc that produces a loud tic noise.
Its gapped at .040 like what i've seen on AZ.
What do you mean by making sure all are tight? The coils?
i purchased NGK Iridium IX. the ones that were 7 bucks a pop. I just used my hand to torque. I just used my judgement I guess. Yes, I did put some anti seize on, but not too much.
