Throttle Question
Throttle Question
If I replaced my throttle w/a Type-S throttle, I was wondering if that would give me more torque as well as top-end hp. If anyone could reply w/their opinions, please do. Thanks.
OG
Since the Type-S throttle body is larger than the regular TLs, it should give you some gain in the top end. You will, however, need to port match it to the intake manifold. Also, you might want to do the I/H/E first before doing the throttle body.
OG
You can get your throttle body bored out, but you will need to find a machine shop to make a custom throttle plate to fit into the new bored out throttle body. Plus, you still would need to port match the intake manifold.
after mkt throttle body!
jc whitney sells a bbk edelbrock high perf throttle body for acuras (all) 92-2000, i believe it's 62mm. since the "res" won't be available for 99's this could be a good alternative . $300.00 5-8 hp gains? i'm trying it out, let ya know! kman
OG
Originally posted by tl-kode16
An aftermarket throttle is even better. Kman, got a webpage for that compnay that makes the throttle bodies?
just got it!
jcwhitney.com sells the bbk edelbrock 62mm high performance throttle body for all honda /acura 92-2000 accord , cl , tl , nsx. claims 8-12 hp gains . bolt on app, also go to www.bbkperformance.com. i'm thinking with the cai and throttle body a high perf fuel pump may be in order? let ya know...kman
navtool.com
31
11-16-2015 08:30 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
navtool.com
09-25-2015 05:15 PM
