throttle body please help!!!!
some body please help i am trying to clean out my Idle Air Control Valve
and i have everything off but the throttle body it just wont come off i have the 4 10mm bolts off the cables off all the hoses. if any body has anything i would appreciate it. i have searched everywhere.
check this thread on removing intake- it also shows how to get the TB off the manifold
https://acurazine.com/forums/showthread.php?t=156252
I had same problem over a year ago w/ my 99TL, TB seemed fused onto IM, ended up removing the upper IM w/ TB attached. Had to clear the EGR port anyway.
It would not separate even when I tried to chisle with hammer and screw driver, (w/ the 2 bolts and 2 nuts removed).
when i took the TB off my friends 02, i tapped it with a rubber mallet around where it meets the manifold and it loosened up. could aslo try a screwdriver/chisel in the gap to try and force them apart.
There is no need to take the TB off. You can remove the 2 screws that hold the IAC on with a little patience.
If you feel the need to remove the TB you will need a new gasket. The TB is just stuck on because of the gasket. If you take a putty knife and start slipping it between the 2 (tapping on it with a hammer to get it between) it will start to separate.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
