for those with comptech sways...
Old Aug 23, 2002 | 09:03 PM
numbaonexstunna's Avatar
man......my rear rattles like crazy.......if i go slow over a bump i hear the rear squeek and rattle & everything.........i know it has to be the sway.....i guess this is y it came with teflon tape...........but i lost it SOOOOOOOOOOOOO wat other thing could i buy from home depot to put on it??
also, if someone could post a pic of certain parts to apply the tape, itd be great =)
thanx
2002 Aegean Blue TL Type S
AEM CAI
AEM Power Pulleys
Apexi' V-AFC
HKS Drager Exhaust
Eibach Pro-Kit (2.1/1.8)
OEM Body Kit
Neuspeed Strut Bar
Comptech Sway Bars
Coming monday: Volk Racing TE37 18" on Yokohama Parada Spec-2
Old Aug 23, 2002 | 10:01 PM
NSXNEXT's Avatar
I'd say something is loose. Check all the bolts and end links to be sure they're tight.
BTW, the teflon tape gets applied on the bar where it sits in the two frame brackets. You can get the tape at any plumbing supply store, Home Depot, etc.
Old Aug 24, 2002 | 08:30 AM
ngcreese's Avatar
I had squeeking on my rear Comptech Sway Bar. It'll happen if you don't use the teflon tape. You can a rool a of it at your local hardware store. It's the same stuff the use as "thread lock" in plumbing applications.
It usually takes only a couple of minutes per side to clean out whatever silicon grease they put on your bushings and replace it with teflon tape.
You wrap the bar with the telfon tape where the bushing and sway bar come in contact with one another (ie: at the mounting brackets(2 points)).
Old Aug 24, 2002 | 01:23 PM
jmai's Avatar
Squeaking is most likely from the rubbing of the urathane bushings. Wrap the teflon tape well around the bar. But rattling is most likely from the end-links screws not being too tight. After i installed my CT sway bars. I drove around for a week and then I had to recheck everything again to ensure everything was correct. My front sways had a full turn after the recheck.
Old Aug 25, 2002 | 11:16 AM
Make sure to remove all the grease you applied first. Apply quite a few layers of the tape on each side and you will be fine. I've been squeak free for atleast 3 months with one application.
Old Aug 26, 2002 | 01:57 PM
WiLz's Avatar
yah, jus go buy some teflon tape and use it. i forgot to put my tape on when i installed it. so i had to take it off and wrap the tape. after i did, there was no more squeaking at all
Old Oct 6, 2003 | 12:23 PM
asloudasitgets's Avatar
how many times do you wrap the bar? i mean how many times do you go around the bar? on each side? with the tape>/?
Old Oct 13, 2003 | 05:05 PM
planetside's Avatar
I talked to a guy at Comptech and he recommended 5 or 6 times around the bar with the teflon tape.
Danny
Jul 16, 2017 07:33 AM
BoricuaTL
Apr 8, 2016 01:08 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
k6biv
Sep 22, 2015 02:06 PM
