TCS and Check engine lights on and tranny shift rough
Old Jan 28, 2013 | 10:06 PM
huynh919's Avatar
Hi guys,
I started up my car this afternoon after work, then see the TCS and Check Engine lights on. When driving, it is very hard and rough to shift between gears. It rev up to around 3.5k RPM before it can shift to 2nd gear and so on...
As an alternative, I had to use sport shift to change gear at lower RPM, but still shutter/rough/tranny making noise while shift.
Anyone has this issue before? what was the problem?
1999 Acura TL 195k miles.
Old Jan 28, 2013 | 10:23 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Originally Posted by huynh919
Hi guys,
You need to get the codes read before we can really help you. Otherwise we are really just suing here guessing. Sounds like a problem with the transmission.
Old Jan 29, 2013 | 12:21 PM
huynh919's Avatar
Just got it fixed.
I go ahead disconnected the battery, replaced the plugs (was original plugs), then clean the EGR port (port clogged up, only a tiny hole about the size of 3 toothpicks.
It seems fine now.
Thanks.
Old Jan 29, 2013 | 12:49 PM
Just got it fixed.
It seems fine now.
Thanks.
Nice did the codes clear? In the future get the codes read so you can help determine what's wrong.
Old Jan 29, 2013 | 07:06 PM
huynh919's Avatar
yeah, the code cleared (for now) as I disconnected the battery before I do the work.
I will post it for sale if anyone interest.
I just purchased the new 2013 Accord Sport this afternoon as I am not sure if the problem comes back.
Thanks guys for your help.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
