TCS and Check Engine Light On....?
Old Aug 20, 2004 | 07:51 PM
02TL_Jax_FL's Avatar
While driving today the TCS and Check Engine Light came on at the same time. I looked in the owners manual but it did not describe this condition. I pulled over and shut off the car when I started up the car and the TCS light went off but the CEL was still lit. I was going to reset the ECU tomorrow. I have been working on older Honda's for awhile (backyard mechanic) and never touched my TL. Does the ECU have a visual led to read the CEL codes or is this all done by the ECU reader systems (Handheld diagnostic computers)?
Any idea of what could be the problem? Thanks
Old Aug 20, 2004 | 08:53 PM
I have had the same issue (TCS & CEL) lit at once several times. According to my Acura service dept., this is caused by the CEL calling out a code that the main computer feels will impact the TCS as well (go figure).
My understanding has always been that the only way to get the diagnostics out/reset was an OBD II reader/module. Usually about $125 on the 'Bay (or check around with your friends or AutoZone - they may let you borrow one).
Good luck.
Old Aug 21, 2004 | 01:37 AM
BlackShadow's Avatar
O.G.
That is usually a sign of the tranny failing. Did the D5 flash also? Are there any hard shifts? If it is then don't worry cause your tranny is covered for 7 yrs/100K miles.
BTW, sure fire sign of tranny slipping: tcs on, cel on, and d5 flashing! Don't feel bad cause there are quite a few 02+ TL-S being affected. And to make you feel better, 99-01 are also affected but not as much.
Old Aug 22, 2004 | 05:09 PM
fsttyms1's Avatar
Originally Posted by BlackShadow
That is usually a sign of the tranny failing. .
no not usually . there are many reasons that when the check engine light comes on that the tcs comes on. i just recently had the same lights on and it was a code P0401.. insufficient egr flow.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
