Switchback leds
Old Sep 24, 2013 | 10:21 PM
thewrangler99's Avatar
Switchback leds
Hi all, I am thinking of buying switchback leds for my 99 tl. I have few questions before I buy. Is it hard to get to the turn signal through fender well? Where should I mount the resistors? Which is the turn signal wire and the ground wire to splice into the resistor? Pictures would be nice if you guys are running switchback leds.
Old Sep 27, 2013 | 12:00 AM
CAB NY's Avatar
Tri State ViP Crew
i have a 03 and it was easy to get to the bulb and the resistor is spliced between the 2 wires and sitting there if i remember but be careful it gets real hot after its hooked up and lights are on
Old Sep 27, 2013 | 11:17 AM
TLer trash's Avatar
There's a thread over in 3rd gen that shows you how to modify the flasher, to eliminate the need for resistors
Old Jan 14, 2014 | 03:49 PM
Gabru678's Avatar
Where is that thread?
I also want to do this and this was the only thread I could find :here
Is there a specific size bulb that our cars use?
Like our headlights are D2r?
Old Jan 14, 2014 | 04:30 PM
03blackbeast's Avatar
I put LEDs in my 03 TL. The way to go around having resistors is to put in a different flasher relay. Autozone carries them for $10. It'll say electronic flasher on it. If for some reason it doesn't then try somewhere else. The relay is located on the back of the drivers side fuse panel. You can locate it under the steering column. If you are looking at the back of it you'll see 3 of those same types of relay boxes in black on the back of where the fuse box is. Remove the one closest to you (at the bottom) and on the farthest right from where you are (closest to the pedals). It's got 2 little clips you'll have to move off from the bottom to get it out. Then just slide in the new relay. It will blink faster than normal but not hyperflash. Then just put in your bulbs like normal and be on your way. Not hard to get to the bulbs through the fender. Just take off the clips on that side and reach in. You can also undo the bolt holding the bumper on and lower the bumper down for even easier access. It's really not a hard thing to do. I tried using the resistors and never could get it to work. The relay is definitely the easiest way to do this mod.
Old Jan 14, 2014 | 05:21 PM
Gabru678's Avatar
Cool!
But what kind of LED did you use?
I looked around and there are alot of different kinds.
Im still trying to find out ours.
Old Jan 14, 2014 | 05:55 PM
The type and number of the LEDs doesn't matter. Just be sure to get the same number as the factory ones. Like if it's a 7447 get a 7447 LED. Once you have the relay in any brand of LED will work.
Old Jan 14, 2014 | 06:39 PM
cincinattlguy19's Avatar
06 NBP 6MT TL
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/switchbacks-899311/
I did it on my 2G TL a couple of months ago, just search
Old Jan 15, 2014 | 12:09 PM
Gabru678's Avatar
Thanks that 7447 was the number I was looking for.
Old Jan 15, 2014 | 05:36 PM
Gabru678's Avatar
I am getting alot of 1157 bulbs that seem to be the right fit (also mentioned in that linked thread) and thanks for finding it! It was in the performance section which might have been why I couldnt find it.
Also I want to get the rear's to round out the whole project, so will those same 1157 bulbs fit on the rear too if I get strictly rear ones? Like the ones I link below?
http://www.ebay.com/itm/1157-AMBER-45-SMD-LED-TURN-TAIL-LIGHT-BULB-1157A-2357A/330593908763?rt=nc
Old Jan 15, 2014 | 05:39 PM
1156 is the size for rear
And make sure they're the amber ones
Old Jan 15, 2014 | 05:45 PM
Gabru678's Avatar
Yep.
I will be getting these for the front
http://www.ebay.com/itm/1157-DUAL-COLOR-SWITCHBACK-WHITE-AMBER-LED-TURN-SIGNAL-CORNER-LIGHT-BULBS-/400333216133?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2003%7CMake%3AAcura%7CModel%3ATL&hash=item5d35b81985&vxp=mtr
And then possibly some cheap ones like this for the rear?
http://www.ebay.com/itm/1156-BA15S-68-SMD-Amber-Yellow-Tail-Fog-Turn-Signal-68-LED-Car-Light-Bulb-Lamp-/261373006531?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cdb0b92c3&vxp=mtr
Am I doing this right?
And thanks alot man you have been alot of help!
Old Jan 15, 2014 | 05:54 PM
Yup looks right to me. Be careful that they rear ones aren't too long for the housing. Mine touch the back of the housing and they weren't long by any means.
Old Jan 15, 2014 | 09:01 PM
Gabru678's Avatar
Hmm that last on is 57mm
might be about 2in.
Seems too big?
Old Jan 16, 2014 | 07:39 AM
Should be ok I would think. That's only like an inch and a half.
Old Jan 16, 2014 | 03:10 PM
bonknhead's Avatar
57mm = 2 1/4 inches.
Old Jan 16, 2014 | 05:16 PM
Gabru678's Avatar
Will that fit?
I tried to google schematics for it, but all I was able to find were the wiring diagrams
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
eastcoastguy
Sep 23, 2015 06:29 AM
