Surging(bouncing) idle
Old Dec 5, 2012 | 10:37 AM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
A month or so ago I swapped in type s ported runners and a type s throttle body and the car ran fine for about two or three weeks except the cruise control plate being broken on the throttle body. Around thanksgiving I as coming off the highway and all the sudden I got a bouncing idle. I put the correct vacuum ports for the type s runners and swapped back to my old throttle body last night. Still the same problem this morning I sprayed everywhere with carb cleaner trying to find the vacuum leak but nothing happened. Anybody have any idea?
Old Dec 5, 2012 | 11:43 AM
666wokker's Avatar
Upside down gaskets maybe? I know some of the gaskets fit both ways, but only one way is correct.
Old Dec 5, 2012 | 12:11 PM
Tried checking that and made sure all the holes longed up perfectly. The weird thing is the car drive fine for a couple of weeks and then out of no where this problem happened
Old Dec 5, 2012 | 12:45 PM
666wokker's Avatar
No codes?
Sounds like a vac leak, or maybe sticky IAC?
Old Dec 5, 2012 | 01:31 PM
No codes?
No codes I sprayed carb cleaner everywhere trying to find the vacuum leak but nothing. I tried switching iacv because I have a couple of throttle bodies right now but that did nothing
Old Dec 5, 2012 | 01:43 PM
I think I might just have to swap back to my stock lower manifold because I've already been without the car for almost two weeks. That's the only other thing I could think it is. I also reused the lower manifold to heads gasket and the lower manifold to top manifold gasket since they were metal. Could that be the problem
Old Dec 5, 2012 | 02:20 PM
666wokker's Avatar
Could be, I know metals are typically reusable to a point.
As a general rule of thumb, and only because I work on SEVERE duty vehicles every day (Taxicabs, 24/7 roadtime) I replace gaskets no matter what they are made of whenever I tear apart a system, you simply never know when it's gonna die, and downtime for us = loss of major money.
Could also be the areas in question are not mating correctly due to very slight differences, but don't quote me on that, I'm not very familiar with the design or construction of the newer runners.
If your problem were mine, I would start by making the whole system stock again, and if it's still not right, investigate further.
Old Dec 5, 2012 | 02:29 PM
Well they were all original gaskets so they had 195,000 miles on them. The type s runners bolt up the same just they have larger openings that were gasket matched. The only bg difference between them was a vacuum port which I switched.
Old Dec 5, 2012 | 06:26 PM
Skirmich's Avatar
Leaks on the Ported Runners + New Manifold?
Old Dec 5, 2012 | 06:49 PM
fsttyms1's Avatar
What do you mean you switched vacuum ports?
Old Dec 5, 2012 | 06:55 PM
There is a vacuum port on the runners like a upside down "L" on type s there are slightly bigger so I ordered new ones and installed them yesterday. I took a look at my old runners and they had little black prices that looked like they went to the gaskets
Old Dec 5, 2012 | 06:56 PM
Te only thing I have on right now is the ported runners and the car drove fine for two or three weeks then out of nowhere it started doing this
Old Dec 5, 2012 | 07:43 PM
2KTL32's Avatar
6th Gear
I've been fighting the same problem on my 2000 TL-P for two years. It's intermittent for me, so easier to live with. I've replaced IACV, TPS, checked for leaks multiple times, cleaned every part on the intake system.......
I think it's a curse.
Old Dec 5, 2012 | 09:29 PM
Yeah unfortunately I don't like driving the car with it like this. I ended up taking it to a shop that my dad knows so he can try to figure it out. I am busy with school and work right now so I'm not able to keep messing with it.
Old Dec 5, 2012 | 10:30 PM
MilwaukeeDave's Avatar
I had this issue after I installed my CAI. I had left a connector unplugged near the throttle body. Is it possible something came loose or unplugged??
Old Dec 5, 2012 | 10:34 PM
There all plugged in I read in another thread that the map sensor and another are the same. I'm wondering if I mixed them up but probably not since the problem came when I was driving and not messing with anything.
Old Dec 5, 2012 | 10:36 PM
When I looked at my old runners tonig I noticed that there were little black peices where te gasket goes so I'm wondering if the gaskets aren't sealing all the way
Old Dec 6, 2012 | 06:39 AM
fsttyms1's Avatar
What little black pieces?
Also, are the vacuum hoses (8/9) hooked up properly/not torn or cracked
Old Dec 6, 2012 | 07:24 AM
#3 is what I replaced. #8&9 had no cracks or tears and slides right on. The little black peices I was referring to looks like its gasket material, There metal but they have some black coating material which is on my old runners
Old Dec 13, 2012 | 02:40 PM
It ended up being the iacv who would've guessed I had to bad ones. I put a brand new one on and it went right back to normal. I've been driving it since last Friday.
Old Dec 13, 2012 | 02:45 PM
Es617's Avatar
Happened to me before bought a used one and did the same broke my head thinking it was something else Glad u got her back up and running right
Old Dec 13, 2012 | 02:53 PM
Yeah I figured it couldn't be that since I swapped it for another one but after we kept searching for a vacuum leak and weren't finding it, I got one from a local autoparts store and but it on and started it up and it went back to normal instantly
DerrickW
Nov 15, 2015 05:52 PM
012TL-GLM
Oct 5, 2015 06:32 AM
Skirmich
Oct 1, 2015 12:59 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
