Sunroof rattle/squeak
My sunroof just started rattling a few days ago and it seems like it's being caused by the rubber seal rubbing against the roof where it seals up. I know that the dealer will put teflon tape on, but where exactly do they put it? Would keeping the seal cleaned and lubricated solve the problem albiet temporarily?
Thanks,
Iggy
Thanks,
Iggy
Mine has been doing the same thing, so how ever way u fix it, let me know ok I only had the car for exactly 3 months today, its like when that cover is back and the sun roof is closed , it rattles so damn loud, i mean i love my car but yo this is an acura it isn't supposed to do that and also what gets me mad is the cheap alarm that we have. Honestly i set the alarm and i'm a strong kid i started shaking my car, sway it side to side, and it didn't go off so that is why tomorrow i'm getting a new alarm with auto start.
When I sent my TL-S in to fix the problem, the dealer put the tape around the moonroof opening (metal side) and also put a layer of silicone grease on the moonroof rubber seal. It fixed the rattling issue but I am not sure how long it will last.
Cheers !!!
Cheers !!!
I have a 1999 Navi (non-S, obviously) but I also had the sunroof rattle problem.
Brought it back 6x to be fixed. Initially, they were putting some type of lubricant on, but finally something unknown to me was done and it has not rattled for over 2 years.
Sorry for being vague, but there is obviously a long term fix for the problem.
I have exactly same problem. I got mine last June and the moonroof started to rattle just about a month ago. The noise was so loud and it's very annoying. Tilting (or opening) and then closing the moonroof occationally (2 out of 10 times) "fix" the noise temporarily.
Re: Sunroof rattle/squeak
Thanks,
Iggy
Thanks,
Iggy
1 Post
Originally posted by nike1678
Also what gets me mad is the cheap alarm that we have. Honestly i set the alarm and i'm a strong kid i started shaking my car, sway it side to side, and it didn't go off so that is why tomorrow i'm getting a new alarm with auto start.
Cheers !!!
Cheers !!!
Well... I'm get used to all rattles now; just like my old Altima.
Fixing the Roof Rattles
The solution for rattle noise or squeeks on the moonroof is to clean the rubber weather seal and lubricate it with a silicone spray or Vinylex or 303 Protectant. The only reason why is because the seal is dry or is dirty.
You may want to consider doing this periodically on all your weather stripping and when you wash you car.
That's my contribution. Good luck!
Cap
Cap
My sunroof used to squeak horribly. The dealership added the teflon tape and it was fixed. They said if I had anymore trouble, the next step was to replace the whole assembly. Well, it still doesn't squeak but now it has a pretty annoying rattle. My 98 Accord EXV6 did the same thing (pretty much the same sunroof). My 95 Accord and 90 & 89 Integras never had any of these problems. Tight as a drum. It seems that since Honda went w/ the flip up and retractable sunroof, they've gone to sh!t. What is really annoying is that my 2000 Chevy Tahoe and my 2002 Nissan Pathfinder have the same type of sunroof and they don't have any problems. Why can't Honda get it right? You shouldn't have to add teflon tape or silicone grease to make them quiet.
No, you are a dork.
My squeak was fixed about 2 mos ago and is still doing fine....however, the rattle is present now and is driving me crazy....shut the roof lid and it goes away....kinda defeats the purpose of having one if it has to stay shut all of the time..
Originally posted by daryl.com
Agreed.
Agreed.
Anyways, since most of the people on this forum is complaining about this, it just shows how much Acura doesn't care about it. I guess they figure it's cheaper to have the dealers fix this when customers complain rather than implementing a permanent fix in their manufacturing process. Do '03 TLs still have this problem?
axleback
I know this thread is veeeeerrry old but i went to the dealership recently to talk about this. and the service manager said that it will cost me 65 bucks because they have to order the special tape for the sunroof and that is $50 and service will be 15 bucks. I left, is there anything i could do?
Try spraying silicone on the rubber seal that is on the moonroof glass.
Clean and wax the opening in the roof. Then clean and silicone or Armor all the seal.
Open the roof slightly to get the front section and open the tilt function to get to the back.
Thanks,
Iggy
Thanks,
Iggy
The rattle is the hardware (an arm) guiding the opening and closing of the sunroof. It is only present when the sliding cover is open and the sunroof is closed. The fix is cleaning and lubrication of the pins and arm that you can see on either side of the sunroof assembly.
The squeak fix is the clean/lube/tape associated with the rubber seal around the glass.
This thread started with discussion of a rattle. Most of the fixes described are for a squeak. There is a difference.
There are two phillips head screws hidden under the map light lens on the center roof console and two under the sun glass holder that tend to vibrate loose also.
mlody
12-04-2019 02:11 PM
