Sucked Up Water Need advice/help
So today, my car sucked up water n died out.
We took out the spark plugs, n ran the water out in the middle of a parking lot. Water shot out like 20 feet.
Changed the oil 2 timee since it was milky.
Car idles preddy smooth but the car hesitates wen acccelerating. Engine check light comes on at mid to high rpms.
Any advice??
I was thinking about changing all the spark plugs n seafoam to help get rid of any moisture n wat not.
Any advice??
i would change out the plugs and then take it for a long drive to see if you can dry out the moisture in the motor and see if that helps
seafoam in the tank and the intake line-
shoot every electrical connecter with wd40 for good measure
Please advise how the water got sucked up so others can avoid this situation
thanks
thanks
I was driving in the far left hand lane. Coming up on 2 lanes under about 6-10 inches of water, i move to the far left hand lane. This lane had about 3-4 inches of water. Im slowly but surely making it through wen a freakin 4x4 truck comes speeding by. Water splashed all on the hood winshield. Im assuming the wave that washed over from his lane caused a unsurge of water into my lane n my car died.
Preddy lame of me next time ill just stop n hold up traffic behind me.
Its a lessoned learnd for me..
low slung CAI sucked past its filter- is that what you mean?
yeah the same exact thing happened to me the other day. i was creepin down a watery raod when a hummer flies by and splashes my car, and it stalls out. i ended up gettin out and shakin the intake filter up n down tryin to get as much water out as i could.
my foot wasnt on the gas at all when i got splashed so im thinkin the intake didnt suck much up. i waited a few mins and it started up with a little bogging down of the engine. then it ran fine for the rest of the day. i just cleaned the filter out and everything seems fine now.
SOLD: 03 SSM CLS Auto
Had a similar experience leaving work last week. I couldn't see the intersection in front of me because of the traffic, and as I'm going through I realize there's about 2-3 feet of water. I see the SUV in front of me going through it no problem, but my CL's lowered atleast 2 inches. I have a stock air box with a K&N filter, but I removed the resonator, so I may have sucked up some water. I'm just glad I don't have a CAI. The engine was not running right for a couple of days until stuff kinda dried out. I'm pretty sure the belts threw some water up into the engine bay cause I had a misfire code right after and the VSA exclimation came on.
u know, u can buy a bypass valve to prevent water from getting to the cylender
http://www.sportcompactonly.com/By-P...arts_c-230.htm
update:
Changed oil a total of 4 times, and changed the spark plugs
Also poured some Marvel Mystery Oil to oil n gas
Car is running preddy smooth
Planning on running another tank of gas then seafoaming n changing the plugs after the seafoam
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
STL TL-S
09-23-2015 08:52 PM
