Strut Bar
Old Jun 29, 2011 | 10:31 PM
KatabaticSaint's Avatar
Strut Bar
I'm curious to know where to buy and what strut bars are good but still decently cheap. I'm also curious to know if a progress RSB is as good as people say and where I can buy one.
Old Jun 30, 2011 | 12:43 AM
01tl4tl's Avatar
the frame crossbar between the strut towers on top of engine, you can add additional suppurt with a cusco bar
more important is a lower frame crossbar- cusco- see MrHeelToe threads in the Black Market Sponsored Sales or www.heeltoeauto.com
has sway bars too, or you can upgrade the current bushings and sway bar end links
Old Jul 10, 2011 | 03:48 PM
jayunsplanet's Avatar
Cusco front upper and lower. You'll notice the lower bar more - feels more solid when you got over bumps at highway speed. *NOTE: It hangs ridiculously low. If you've lowered your car, you'll scrape everything. I went through 2 lower braces before giving up on them.
Progress RSB for the 3G TL is nice. The initial hard turn and weaving in a parking lot after you install it will blow your mind. I got used to it after awhile. Would have been nice to drive a stock 2G to re-feel the difference again.
My setup was:
Wider grippy solid tires + lighter wheels (rpf1s) + coilovers (tein ss-p) + strut braces + progress rsb = much better handling glorified Honda Accord.
(Pretty sure I've written an identical sounding post on this subject before.)
Old Jul 11, 2011 | 10:22 AM
01tl4tl's Avatar
I scrape ~sometimes~ but the bar also protects the cat as it hangs slightly lower than it
better an 80 dollar bar loose some metal than an expensive order thru excelerate and install a new cat. Bar still performs the same minus some paint
learn to cross bumps and dips at an angle- that reduces most of the problem,
except those really bad driveways or wide speed bumps
Old Jul 11, 2011 | 10:24 AM
fsttyms1's Avatar
My setup was:
And you would notice an even BIGGER difference if you had a Front sway bar.
Old Jul 11, 2011 | 10:31 AM
jjashaa's Avatar
Avant Garde Wheels
if you could find a comptech one.. its a 4 pt from what i remember....
and the neuspeed one goes over the stock strut tower bar
Old Jul 11, 2011 | 10:43 AM
gold2003tl (90)'s Avatar
2003 TL-p
what brand and size front sway bar do you have? Eibach 27mm? does installation require dropping the exhaust?
i see XLR8 now offers a front sway bar made by ST, but its 22mm and doesnt seem to be large enough. has anyone tried the ST front sway bar?
i currently have progress 24mm rear sway bar, and B&G sk2 shocks and springs. the car handles great and is flat, the front could be tighten up a bit thats all.
Old Jul 11, 2011 | 10:49 AM
jjashaa's Avatar
Avant Garde Wheels
he has eibach front and rear....
eibach shows 29 and 23
Old Jul 11, 2011 | 01:07 PM
fsttyms1's Avatar
Eibach. I never understood why people only upgraded the rear. Sure it makes the car a little more neutral but it isnt doing anything to help the front squat and roll. Adding a match set of front and rears will make the car handle more neutral and better. The front heavy fwd needs the front to be kept in check better. My lap times dropped drastically by adding the front over just the rear (tried at a track to see the handling difference). I can get oversteer with my car fairly easily with adjusting the rear shocks a little stiffer.
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
lanechanger
Oct 13, 2015 10:56 AM
hashbrown
Sep 29, 2015 12:13 PM
