Strange VSA problem
Old Jan 20, 2010 | 07:31 AM
sleeperblue's Avatar
Strange VSA problem
The VSA and ABS light come on when the tires lose traction, as is should, but, stays on afterward. After turning the car off and restarting it, the lights go off. What to look at, wheel sensors? TB VSA switch?
thanks!
Old Jan 20, 2010 | 07:56 AM
fsttyms1's Avatar
Maybe next time they come on bring the car to a auto parts store to see if they can get a code while they are on.
Old Jan 20, 2010 | 11:12 AM
01tl4tl's Avatar
how are you causing them to lose traction? ice at stop signs?
are you intentionally making it do the work, with the system hammering the ABS to slow the spinning wheel?
It only goes to 16mph -25kph and stops working, figuring by that time you have let off the gas and regained control
Old Jan 20, 2010 | 11:15 AM
01tl4tl's Avatar
as said above- try to get to a parts store with it running and light on
they can try and pull the codes without the warning light on but it doesnt always store every code-
worth a try today, then next time it happens, call on your way over so you dont have to shut off the car
possible suspect speed sensor at wheels- wire corrodes or gets damaged/broken at brake service, or debris on road can snag the wire
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
