Stock Deck with aftermarket subs, need HELP!
Need my Daily Fix of AZ
i need some help with my stock deck and aftermarket sub set up
i know that the TL Bose stock deck does not come with the RCA, so i bought a Line converter
i took the stock subs out.. and NOW i don't know how to connect the Line converter...The box says i should connect it to 2 speakers but both speakers are on the doors.. is there another way?
there are 5 wires on the line converter *1 is ground and 4 goes to the speakers*
the other side is the RCA
Where do i connect the 4 speaker wires? can i splice my stock bose connectors(stock Red wire with 2 Line converter wires X2 and ground with 2 stock Black wires??)
i have a visual some it's easier for everyone.
Thanks for any Help and lets get me Boom BOoming around town
i've already done this. Its difficult to figure out at first, but u take both left and right connectors of the line convertor and connect them to directly to the wires going into the sub. If u look at the sub, there's 4 wires going into it. u have to connect ALL 4, otherwise u wont get proper sound. there are 2 wires going into left and 2 going into right. I connected only two at first, and i got too much deep bass and no thumping bass.
U can either connect them underneath the sub, or connect them where the amp is behind the back seat. Mines beside the amp.
1 Post
you do not need to use a line output converter.
the stock sub has rca's that you can tap into. See this thread:
https://acurazine.com/forums/audio-video-electronics-navigation-22/need-help-advice-anything-adding-sub-185395/
It will sound much better this way too.
thanks!
i got the fking subs working but then THE POS Line convter BROKE ON ME!
WTF!iweufaiwofugefiuageioawg the gain controls on it fell APART!
now i'll be using the method you have given me but i don't understand the puke Brown part. damn so sad
i opend up the puke brown shield to find twisted exposed wire and a inner guage wire*ornage* am i supose to expose that one too? is that the right procedure?
anyone comfirm?
THanks abunch.
anyone comfirm?
THanks abunch.
https://acurazine.com/forums/showthread.php?t=185395
4drviper
09-23-2015 09:00 PM
4drviper
09-23-2015 07:42 PM
rboller
09-23-2015 02:49 PM
