Steering problem
Steering problem
At low speeds the steering wheel oscillates as if the front wheels are out of balance, but feels sorta like the hydraulic pump is surging. It is possible the wheels need a rebalance, but thinking there might be power steering issues too. It goes away after reaching 25 mph or so. Any thoughts?
rollinstone
rollinstone
What do your tires look like. Over inflated? underinflated? Unevenly worn?
tire's are in very good shape...no wear patterns...tire pressure is good...checked regularly as is rotation. she's got 70K, tho so i'm sure a rebalance wouldn't hurt.
do you have any power steering noise?
oscillating under 25 mph
Typically wheel balance and alignment issues intensify at higher speeds. First thing to check would be your PS pump's belt tension and also the pump's fluid condition and level. Next, check your lug nut's torque and tire pressure. Finally, if it's been awhile since your last check for alignment/suspension/balance........try that.
So the steering wheel physically moves? Is there any tire noise? About the only thing i can think of are tires, or the speed sensor for the variable assist steering(haven't seen one of these causing a issue yet, nor am i sure it would cause your symptoms)
marcelft
07-10-2018 06:17 PM
EvilVirus
12-10-2015 07:38 PM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
