Steering problem
Old Apr 1, 2008 | 10:30 AM
rollinstone's Avatar
Steering problem
At low speeds the steering wheel oscillates as if the front wheels are out of balance, but feels sorta like the hydraulic pump is surging. It is possible the wheels need a rebalance, but thinking there might be power steering issues too. It goes away after reaching 25 mph or so. Any thoughts?
rollinstone
Old Apr 1, 2008 | 01:49 PM
fsttyms1's Avatar
What do your tires look like. Over inflated? underinflated? Unevenly worn?
Old Apr 1, 2008 | 11:35 PM
Calilove4L's Avatar
B A N N E D
unbalanced wheels and excessive toe may be the culprit
Old Apr 2, 2008 | 02:05 AM
tire's are in very good shape...no wear patterns...tire pressure is good...checked regularly as is rotation. she's got 70K, tho so i'm sure a rebalance wouldn't hurt.
Old Apr 2, 2008 | 07:09 AM
fsttyms1's Avatar
do you have any power steering noise?
Old Apr 2, 2008 | 08:38 AM
3.2TLc's Avatar
oscillating under 25 mph
Typically wheel balance and alignment issues intensify at higher speeds. First thing to check would be your PS pump's belt tension and also the pump's fluid condition and level. Next, check your lug nut's torque and tire pressure. Finally, if it's been awhile since your last check for alignment/suspension/balance........try that.
Old Apr 2, 2008 | 10:07 AM
fsttyms1: nope, no noise.
3.2TLc: will follow your checklist...tks.
Old Apr 2, 2008 | 11:52 AM
fsttyms1's Avatar
So the steering wheel physically moves? Is there any tire noise? About the only thing i can think of are tires, or the speed sensor for the variable assist steering(haven't seen one of these causing a issue yet, nor am i sure it would cause your symptoms)
Feb 25, 2020 09:57 AM
spidermankb
Mar 5, 2019 11:34 AM
marcelft
Jul 10, 2018 06:17 PM
EvilVirus
Dec 10, 2015 07:38 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
