Starting problem with my 2003 TL
Got this car two month ago. Had the starting problem about 6-8 times ever since then (twice at gas station). When I cranked the key (tried the valet key also), it did not start. However, it started after I left the car for a few minutes and cranked again. I also had to reset the digital clock a few times after starting failure. Is anybody experiencing the same problem? I'd appreciate if anybody can give some suggestion.
05 C230K & 09 135i 6MT
Do all accessories come on properly? Lights? Are they dim? Do you hear any "click"ing?
It does sound simply like a battery problem, especially since you've had to reset the clock. If it's an 03, and has less than 50k miles, you are probably still under warranty.
i had the same problem a couple of times, though it might be the starter because even after jumping the car wouldnt start, but if left alone for about an hour it would start up. it turned out to be a dying battery, been fine since i installed a new battery.
Originally Posted by frankg
how often do most of you guys change your oil. I have always changed my oil every 5000 km, but I'm told I should stick to the manual . 2003 tl type-s
saberlove
03-11-2021 09:29 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
