Starting problem with my 2003 TL
Old Jan 22, 2006 | 11:54 PM
mcsquare's Avatar
Got this car two month ago. Had the starting problem about 6-8 times ever since then (twice at gas station). When I cranked the key (tried the valet key also), it did not start. However, it started after I left the car for a few minutes and cranked again. I also had to reset the digital clock a few times after starting failure. Is anybody experiencing the same problem? I'd appreciate if anybody can give some suggestion.
Old Jan 23, 2006 | 01:30 AM
khoifl's Avatar
I suspect it's your battery. Try to go to autozones or auto part stores, to get a free battery check-up.
Old Jan 23, 2006 | 02:39 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Do all accessories come on properly? Lights? Are they dim? Do you hear any "click"ing?
It does sound simply like a battery problem, especially since you've had to reset the clock. If it's an 03, and has less than 50k miles, you are probably still under warranty.
Old Jan 23, 2006 | 07:19 AM
wilp99's Avatar
prolly the battery terminals not on tight.. or bad ground.
Old Jan 23, 2006 | 10:04 AM
acurabum's Avatar
Clean the battery terminals and tight them right ...And test it !
Old Jan 23, 2006 | 11:17 AM
DonClaude75's Avatar
i had the same problem a couple of times, though it might be the starter because even after jumping the car wouldnt start, but if left alone for about an hour it would start up. it turned out to be a dying battery, been fine since i installed a new battery.
Old Oct 6, 2006 | 06:44 PM
frankg's Avatar
Question oil changes
how often do most of you guys change your oil. I have always changed my oil every 5000 km, but I'm told I should stick to the manual . 2003 tl type-s
Old Oct 6, 2006 | 06:58 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
Old Oct 6, 2006 | 07:01 PM
Phesto's Avatar
I am using amsoil so I'll try to get 7,500 miles between changes.
saberlove
Mar 11, 2021 09:29 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
