Starter Trouble
Old Jan 24, 2005 | 08:46 AM
SHINY TL-13's Avatar
GO TIME
Starter Trouble
So I went to start my car this morning and it did not start right away. Is that bad for the car when the electric start is constantly trying to turn over? Usually the car starts right up but this morning it took a little longer.
Old Jan 24, 2005 | 08:54 AM
69ssrscam's Avatar
2003 SSM TLS
It is not terribly bad for the starter to have to turn the car over a little extra, but I wouldn't run it into the ground either. Probably just due to it being really cold. If it continues, I would look to a fresh cold start battery with a high CCA number (cold cranking amps). That should help spin that starter a little better.
Old Jan 24, 2005 | 09:07 AM
fsttyms1's Avatar
what do you mean it didnt start right away? did you have to try to crank it many times? how long did you have to let it crank?
Old Jan 24, 2005 | 09:11 AM
soopa's Avatar
The Creator
your battery is probably just running a little low on juice. mine is too... i'm having same problems.
Old Jan 24, 2005 | 09:12 AM
soopa's Avatar
The Creator
oh and remember... a battery loses 60% of whatever power it when its below freezing...
so imagine what its like when below 0?
if you are already running low on power you likely have merely 10% of juice in this weather.
Old Jan 24, 2005 | 09:16 AM
TeknoKing's Avatar
yep, Soopa is correct, your battery has little cold amps due to the weather, and it is probably not being charged fully by the alternator.
you can get a special battery cover that keep the battery warmer, or a new battery, or just wait for the summer
Old Jan 24, 2005 | 11:10 AM
GO TIME
thanks for the input guys. I think I will purchase a new battery this week.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
agupta3224
Sep 22, 2015 08:08 PM
