Squealing break
Old Apr 22, 2003 | 12:34 AM
zerosky's Avatar
Squealing break
I installed front axxis metal master break pads with resurfaced rotors about 3k miles ago, and front breaks started to squeal. I think there's nothing wrong with break performance but when I break hard, they make a lot of noise during 15~0mph. Does anyone know what the problem is??
Old Apr 22, 2003 | 12:37 AM
pianoman41's Avatar
If you didn't replace the shims at the time the pads were replaced, and/or if you didn't put some anti-squeal compound on the backside of the pads, then it is quite common for brakes to squeal when pressure is applied.
Old Apr 22, 2003 | 09:19 AM
ArN 2000 TL's Avatar
Moderator Alumnus
same thing with me....my installer did replace the shims and they squeal now, but its only if i brake very light...like rolling to a stop, parking lot driving, etc..
Old Apr 22, 2003 | 12:05 PM
TLdude's Avatar
when installing semi metallic or full metallic pads ur going to get some noise...and its not good with the stock rotors...the stock rotors are too soft for the metallic pads...ur going to need to replace ur rotors soon...oem is organic so not much if any noise...
lanechanger
Oct 13, 2015 10:56 AM
2012wagon
Sep 29, 2015 04:21 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
peti1212
ILX
Sep 22, 2015 11:11 AM
